05-26-2012 02:19 AM - edited 03-16-2019 11:21 AM
Dear NetPro gurus,
My customer has recently setup a new CUE with the existing CME. Everything works and users can retreive voicemails except MWI.
I have attached the CME configs as attached. Also, i have attached the debugs as below when I initiated "MWI refresh".
ce-e03-1#
May 26 2012 09:12:58.524 UTC: //6691/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:10.69.11.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.69.250.83:5060;branch=z9hG4bK19E6CB
To: <sip:10.69.11.1>
Date: Sat, 26 May 2012 09:12:58 GMT
Call-ID: D2151E26-A64911E1-9A9A84E2-464F7003@10.69.250.83
User-Agent: Cisco-SIPGateway/IOS-15.2.2.T1
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <sip:10.69.250.83:5060>
Content-Length: 0
May 26 2012 09:12:58.524 UTC: //6692/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.69.250.83:5060;branch=z9hG4bK19E71AC
Call-ID: D2151E26-A64911E1-9A9B84E2-464F7003@10.69.250.83
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
May 26 2012 09:12:58.528 UTC: //6693/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.69.250.83:5060;branch=z9hG4bK19E8199
Call-ID: D215BAE6-A64911E1-9A9C84E2-464F7003@10.69.250.83
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
May 26 2012 09:12:58.528 UTC: //6694/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.69.250.83:5060;branch=z9hG4bK19E91DEF
Call-ID: D215BAE6-A64911E1-9A9D84E2-464F7003@10.69.250.83
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
May 26 2012 09:12:58.544 UTC: //6691/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Content-Length: 0
To: <sip:10.69.11.1>;tag=27483156
CSeq: 101 OPTIONS
May 26 2012 09:12:58.544 UTC: //6692/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Content-Length: 0
To: <sip:10.69.11.1>;tag=1311376281
CSeq: 101 OPTIONS
May 26 2012 09:12:58.548 UTC: //6693/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Content-Length: 0
To: <sip:10.69.11.1>;tag=650594590
CSeq: 101 OPTIONS
May 26 2012 09:12:58.548 UTC: //6694/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Content-Length: 0
To: <sip:10.69.11.1>;tag=1369032143
CSeq: 101 OPTIONS
Cheers,
Hunt
05-26-2012 03:25 AM
Hi Hunt Lee,
Can you check that the same number has been configured for MWI ON/OFF in CUE..
type show ccn application
check that the mwi number in
strMWI_OFF_DN:
strMWI_ON_DN:
is the same as configured on CCME.
Also when you did your mwi refresh, there is no invite coming from CUE to CCME to change the state of the MWI LAMP.
Can you ensure that the sip gateway address on your cue is the ip address of the ccme router using the command below:
sh ccn subsystem sip
05-26-2012 04:45 AM
Add this
sip-ua
mwi-server ipv4:x.x.x.x expires 3600 port 5060 transport udp
05-26-2012 04:56 AM
Opps also need to add under all ephone- dn
Ephone- dn
Mwi sip
05-26-2012 05:14 AM
hi Hunt,
on the cue ...do a "show ccn application"....this will show you mwi on and off numbers.
The system does not have a concept of the number of digits in the extensions; it simply places a call to the
appropriate MWI on or off number and appends the mailbox extension. The Cisco CallManager Express
system must have a dial peer with the appropriate number of dots in the destination pattern in order to route
the call properly.
Finally, be sure that the Cisco Unity Express SIP gateway IP address points to the correct Cisco CallManager express . "show ccn subsystem sip"
to check this.
Hope this helps!
Karthik
05-29-2012 09:06 PM
Hi guys,
From the CUE ISM module, i can ping the CME without any problems.
CME itself: 10.69.254.30
CUE ISM card: 10.69.254.28
There are 4 unread Voicemail on the IP Phone, but MWI just won't work...
interface ISM0/0
description CUE running on SRE Module
ip vrf forwarding voip
ip address 10.69.254.30 255.255.255.248
service-module ip address 10.69.254.28 255.255.255.248
!Application: CUE Running on ISM
service-module ip default-gateway 10.69.254.30
end
On CUE Module
se-10-69-45-253# ping 10.69.254.30
PING 10.69.254.30 (10.69.254.30) 56(84) bytes of data.
64 bytes from 10.69.254.30: icmp_seq=1 ttl=255 time=0.161 ms
64 bytes from 10.69.254.30: icmp_seq=2 ttl=255 time=0.109 ms
64 bytes from 10.69.254.30: icmp_seq=3 ttl=255 time=0.108 ms
64 bytes from 10.69.254.30: icmp_seq=4 ttl=255 time=0.108 ms
64 bytes from 10.69.254.30: icmp_seq=5 ttl=255 time=0.109 ms
--- 10.69.254.30 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.108/0.119/0.161/0.021 ms, ipg/ewma 0.164/0.139 ms
se-10-69-45-253# ping 10.69.254.28
PING 10.69.254.28 (10.69.254.28) 56(84) bytes of data.
64 bytes from 10.69.254.28: icmp_seq=1 ttl=64 time=0.058 ms
64 bytes from 10.69.254.28: icmp_seq=2 ttl=64 time=0.012 ms
64 bytes from 10.69.254.28: icmp_seq=3 ttl=64 time=0.007 ms
64 bytes from 10.69.254.28: icmp_seq=4 ttl=64 time=0.007 ms
64 bytes from 10.69.254.28: icmp_seq=5 ttl=64 time=0.006 ms
--- 10.69.254.28 ping statistics ---
rtt min/avg/max/mdev = 0.006/0.018/0.058/0.020 ms, ipg/ewma 0.054/0.037 ms
se-10-69-45-253#
se-10-69-45-253# show ccn application
Description: sip
Application type: aa
Script: noscript
ID number: 6
Enabled: yes
Maximum number of sessions: 8
Description: promptmgmt
Script: promptmgmt.aef
ID number: 4
Enabled: yes
Maximum number of sessions: 1
appManagementScript:
Description: autoattendant
Script: aa.aef
ID number: 1
Enabled: yes
Maximum number of sessions: 10
allowExternalTransfers: false
busClosedPrompt: AABusinessClosed.wav
businessSchedule: systemschedule
busOpenPrompt: AABusinessOpen.wav
dialByExtnAnytime: false
dialByExtnAnytimeInputLength: 4
dialByFirstName: false
disconnectAfterMenu: false
holidayPrompt: AAHolidayPrompt.wav
MaxRetry: 3
operExtn:
welcomePrompt: AAWelcome.wav
Description: voicemail
Script: voicebrowser.aef
ID number: 2
Enabled: yes
logoutUri: http://localhost/voicemail/vxmlscripts/mbxLogout.jsp
uri: http://localhost/voicemail/vxmlscripts/login.vxml
Description: msgnotification
Script: msgnotify.aef
ID number: 5
Enabled: yes
DelayBeforeSendDTMF: 1
Description: ciscomwiapplication
Script: setmwi.aef
ID number: 3
Enabled: yes
CallControlGroupID: 0
strMWI_OFF_DN: 8280
strMWI_ON_DN: 8281
se-10-69-45-253# sh ccn subsystem sip
SIP Gateway: 10.69.254.30
SIP Port Number: 5060
DTMF Relay: sip-notify,sub-notify
MWI Notification: unsolicited,sub-notify
MWI Envelope Info: enabled
Transfer Mode: bye-also
SIP RFC Compliance: Pre-RFC3261
se-10-69-45-253#
I have re-attached both CME & CUE configs.
Would apprecited any help on this.
Cheers,
Hunt
06-19-2013 01:42 PM
Hi Hunt
I check yur configuratin of CUE just need to remove the unsolicited command from ccn subsystem sip "no mwi sip unsolicited sub-notify" it will work fine>>>
07-21-2016 03:28 PM
Hello
I have the same problem, any solution?
GATEWAY 2911
TELEPHONES: 7821, 7841
CME: 172.16.1.1
CUE: 172.16.1.2
CME
USER:
voice register dn 8
number 816
call-forward b2bua busy 1000
call-forward b2bua mailbox 1000
call-forward b2bua noan 1000 timeout 10
allow watch
pickup-call any-group
pickup-group 10
name Claudio Rangel
label 816 Claudio Rangel
mwi
dial-peer voice 1000 voip
description al unity express
destination-pattern 1000
b2bua
session protocol sipv2
session target ipv4:172.16.1.2
dtmf-relay sip-notify
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:172.16.1.2 expires 3600 port 5060 transport udp unsolicited
GNP_GATEWAY#show voice register global
CONFIG [Version=10.0]
Version 10.0
Mode is cme
Max-pool is 55
Max-dn is 55
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is 172.16.1.1 port 5060
Authenticate register
Authenticate realm lab.local
NTP Server Address is 172.16.1.1
NTP Server Mode is: directedbroadcast
Time-format is 24
Date-format is D/M/Y
Time-zone is 9
Hold-alert is disabled
Mwi stutter is enabled
Mwi registration for full E.164 is enabled
CUE
CUEGNP# show user detail username claudio
Username: claudio
Full Name: Claudio rangel
First Name: Claudio
Last Name: rangel
Nickname: Claudio rangel
Phone: 816
Phone(E.164):
Fax:
Email:
Epage:
Language: es_MX
GroupMember: <none>
GroupOwner: <none>
Privileges: <none>
CUEGNP# show ccn subsystem sip
SIP Gateway: 172.16.1.1
MWI Envelope Info: disabled
Transfer Timeout: 6
Transfer Timeout: 6
CUEGNP# show ccn app
CUEGNP# show ccn application
Description: Cisco Auto-Attendant
Script: aa.aef
ID number: 1
Enabled: yes
Maximum number of sessions: 2
allowExternalTransfers: true
busOpenPrompt: Conmutador_aps_1.wav
dialByExtnAnytime: true
dialByExtnAnytimeInputLength: 3
MaxRetry: 0
operExtn: 800
welcomePrompt: Conmutador_aps_3segs_1u.wav
ID number: 4
Enabled: yes
Description: Cisco Voicemail
ID number: 2
Enabled: yes
ID number: 5
Enabled: yes
Script: setmwi.aef
ID number: 3
Enabled: yes
strMWI_OFF_DN: 8001
strMWI_ON_DN: 8000
I keep the following documentation
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-express/60081-unity-mwi-problems.html
no trace all
trace ccn stacksip dbug.
mwi refresh
show trace buffer long
CUEGNP# show trace buffer long
Press <CTRL-C> to exit...
11456 07/21 15:48:05.840 ACCN SIPL 0 SIP NewInvitationCallback.invitation()
INVITE sip:1000@172.16.1.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.1.1:5060;branch=z9hG4bK722BF2228;x-route-tag="tgrp:AXTEL"
Max-Forwards: 69
To: <sip:1000@172.16.1.2>
From: <sip:5545586137@172.16.1.1>;tag=8935D068-1FEB
Call-ID: 8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
CSeq: 101 INVITE
Content-Length: 451
Remote-Party-ID: <sip:5545586137@172.16.1.1>;party=calling;screen=no;privacy=off
Date: Thu, 21 Jul 2016 21:47:31 GMT
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2407445159-1321406950-2270663624-1320671749
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M6
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Timestamp: 1469137651
Contact: <sip:5545586137@172.16.1.1:5060>
Call-Info: <sip:172.16.1.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Diversion: <sip:816@172.16.1.1>;privacy=off;reason=no-answer;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Type: multipart/mixed;boundary=uniqueBoundary
MIME-Version: 1.0
--uniqueBoundary
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=CiscoSystemsSIP-GW-UserAgent 875 8068 IN IP4 172.16.1.1
s=SIP Call
c=IN IP4 172.16.1.1
t=0 0
m=audio 16716 RTP/AVP 0
c=IN IP4 172.16.1.1
a=rtpmap:0 PCMU/8000
a=ptime:20
--uniqueBoundary
Content-Type: application/gtd
Content-Disposition: signal;handling=optional
IAM,
GCI,8f7eb2a74ec311e6875793c84eb7da05
--uniqueBoundary--
11456 07/21 15:48:05.841 ACCN SIPL 0 SIP invitation: targetNumber=1000
11456 07/21 15:48:05.843 ACCN SIPL 0 LocalLine[1000] process invitation, callId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, globalCallId=null from SIP-Remote-MT-8282 dn=5545586137 addr=172.16.1.1:16716, dtmf=-1, codecs=[0], ptime=20, mediaStarted=false (sip:5545586137@172.16.1.1)
11456 07/21 15:48:05.843 ACCN SIPL 0 LocalLine[1000] InboundCallInfo=SIP-InboundCallInfo: source=5545586137, (sip:5545586137@172.16.1.1), destination=1000, (sip:1000@172.16.1.2), callId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, gcId=null, lastRedirectDN=816, (sip:816@172.16.1.1), originalCalledDN=816, callingDisplayName=null, arrivalType=no-answer
11456 07/21 15:48:05.843 ACCN SIPL 0 NewInvitationCallback: creating new call
11456 07/21 15:48:05.843 ACCN SIPL 0 SIP-Call-4142:IDLE[] <init>
11456 07/21 15:48:05.843 ACCN SIPL 0 SIP-Provider: getAbstractLine: creating RemoteLineImpl for DN 5545586137
11456 07/21 15:48:05.843 ACCN SIPL 0 RemoteLine[5545586137@172.16.1.1]: created
11456 07/21 15:48:05.843 ACCN SIPL 0 Call.createConnection: this=SIP-Call-4142:IDLE[], line=RemoteLine[5545586137@172.16.1.1], state=ACTIVE, sc=null, mt=[SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false], addToCall=true
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8283-5545586137] ConnectionState.<init>: state=ACTIVE
11456 07/21 15:48:05.844 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false] associate with [SIP-Conn-8283, dn=5545586137, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=ACTIVE]
ctrl=[CSTA-SC-8283], MT=[[SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false]]
11456 07/21 15:48:05.844 ACCN SIPL 0 CallManager.put: callIdImpl=[8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1,null,4142]
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8283-5545586137] <init>: [SIP-Conn-8283, dn=5545586137, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=ACTIVE]
11456 07/21 15:48:05.844 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE] addCallListener com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@6e9b6a
11456 07/21 15:48:05.844 ACCN SIPL 0 Call.createConnection: this=SIP-Call-4142:ACTIVE[5545586137:ACTIVE], line=LocalLine[1000], state=IDLE, sc=ltp8282-1000, State=IDLE: , mt=[SIP-Local-MT-8283 dn=1000 no media], addToCall=true
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8284-1000] ConnectionState.<init>: state=IDLE
11456 07/21 15:48:05.844 ACCN SIPL 0 [SIP-Local-MT-8283 dn=1000 no media] set connection [SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=IDLE]
ctrl=[ltp8282], MT=[[SIP-Local-MT-8283 dn=1000 no media]]
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8284-1000] <init>: [SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=IDLE]
11456 07/21 15:48:05.844 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:IDLE] addCallListener com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@6e9b6a
11456 07/21 15:48:05.844 ACCN SIPL 0 New InvitationCallback from LocalLine[1000] creates SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:IDLE]
11456 07/21 15:48:05.844 ACCN SIPL 0 NewInvitationCallback.processInvitation: id=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, callId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, lastRedirectedDN=816, originalCalledDN=816, originalCallingDN=5545586137, calledDN=1000, parentGlobalCallId=null, type=1002, arrivalType=1002
11456 07/21 15:48:05.844 ACCN SIPL 0 LocalLine[1000] process inbound call, gcId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
Local: [SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=IDLE]
ctrl=[ltp8282], MT=[[SIP-Local-MT-8283 dn=1000 no media]] LocalLine[1000]
Remote: [SIP-Conn-8283, dn=5545586137, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=ACTIVE]
ctrl=[CSTA-SC-8283], MT=[[SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false]] RemoteLine[5545586137@172.16.1.1]
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8284-1000] onCallConnectionOffered: state=IDLE
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8284-1000] setState: IDLE -> OFFERED
11456 07/21 15:48:05.845 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_OFFERED (1000) call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:OFFERED]
EVCall=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:OFFERED]EVConn=[SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=OFFERED]
11456 07/21 15:48:05.845 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@6e9b6a
4601 07/21 15:48:05.846 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:OFFERED] addCallListener com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4601 07/21 15:48:05.846 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:OFFERED] removeCallListener com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@6e9b6a
4601 07/21 15:48:05.849 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false] - add MediaListener com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4601 07/21 15:48:05.849 ACCN SIPL 0 [SIP-Local-MT-8283 dn=1000 no media] - add MediaListener com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4601 07/21 15:48:05.852 ACCN SIPL 0 ltp8282-1000, State=ALERTED: process Invite, callId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
4601 07/21 15:48:05.853 ACCN SIPL 0 ltp8282-1000, State=ALERTED: sending ringing response:
SIP/2.0 180 Ringing
To: <sip:1000@172.16.1.2>;tag=ds131e2f69
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:1000@172.16.1.2:5060;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
4601 07/21 15:48:05.853 ACCN SIPL 0 ltp8282-1000, State=ALERTED: setDialog: com.dynamicsoft.DsLibs.DsSipDialog.DsSipInviteDialog@1487e6b isConfirmed=false
4601 07/21 15:48:05.853 ACCN SIPL 0 [Conn-8284-1000] onCallConnectionRinging: state=OFFERED
4601 07/21 15:48:05.853 ACCN SIPL 0 [Conn-8284-1000] setState: OFFERED -> RINGING
4601 07/21 15:48:05.853 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_RINGING (1000) call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:RINGING]
EVCall=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:RINGING]EVConn=[SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=RINGING]
ctrl=[ltp8282], MT=[[SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=false]]
4601 07/21 15:48:05.853 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4037 07/21 15:48:05.862 ACCN SIPL 0 ltp8282-1000, State=ALERTED: sending ok response for dialog
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 127
Call-Info: <sip:172.16.1.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CUE 3612371 2 IN IP4 172.16.1.2
s=SIP Call
c=IN IP4 172.16.1.2
t=0 0
m=audio 21426 RTP/AVP 0
4037 07/21 15:48:05.862 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false]: getDtmfMethodOut: sip-notify
4037 07/21 15:48:05.862 ACCN SIPL 0 ltp8282-1000, State=ALERTED: initDtmf: dtmfMethodIn=sip-notify
4037 07/21 15:48:05.862 ACCN SIPL 0 DtmfSubscription.<init>: unsolicited=true
4609 07/21 15:48:05.870 ACCN SIPL 0 ltp8282-1000, State=ALERTED: processAck Call-ID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 isReplacing=false, body=null
4609 07/21 15:48:05.870 ACCN SIPL 0 [Conn-8284-1000] onCallConnectionActive: state=RINGING
4609 07/21 15:48:05.870 ACCN SIPL 0 [Conn-8284-1000] setState: RINGING -> ACTIVE
4609 07/21 15:48:05.870 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_ACTIVE (1000) call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:ACTIVE]
EVCall=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:ACTIVE]EVConn=[SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=ACTIVE]
, cause=ANSWERED
4609 07/21 15:48:05.870 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4609 07/21 15:48:05.871 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_ANSWERED call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:ACTIVE]
CALL_ANSWERED
4609 07/21 15:48:05.871 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4609 07/21 15:48:05.871 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false]
dispatch media MEDIA_STARTED Event: [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false] to com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4609 07/21 15:48:05.874 ACCN SIPL 0 [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=false]
dispatch media MEDIA_STARTED Event: [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=false] to com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4609 07/21 15:48:27.377 ACCN SIPL 0 ltp8282-1000, State=CONNECTED: processTerminated
BYE sip:1000@172.16.1.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.16.1.1:5060;branch=z9hG4bK722C1997;x-route-tag="tgrp:AXTEL"
Max-Forwards: 69
CSeq: 102 BYE
Content-Length: 0
Timestamp: 1469137672
Reason: Q.850;cause=16
P-RTP-Stat: PS=1074,OS=171840,PR=693,OR=110403,PL=0,JI=0,LA=0,DU=21
4609 07/21 15:48:27.377 ACCN SIPL 0 ltp8282-1000, State=CONNECTED: setDisconnected processTerminated, cause=NORMAL
4609 07/21 15:48:27.377 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:ACTIVE] clearId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
4609 07/21 15:48:27.377 ACCN SIPL 0 ##### ltp8282-1000, State=DISCONNECTED: ##### [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=true] ##### [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=true]: ##### ltp8282-1000, State=DISCONNECTED: ##### [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=true] ##### [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=true]
4609 07/21 15:48:27.378 ACCN SIPL 0 [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=true]
dispatch media MEDIA_STOPPED Event: [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=true] to com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4609 07/21 15:48:27.378 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=true]
dispatch media MEDIA_STOPPED Event: [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=true] to com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE], remove connection 1000, last=false
4609 07/21 15:48:27.378 ACCN SIPL 0 [Conn-8284-1000] onCallConnectionDisconnected: state=ACTIVE, cause=NORMAL
4609 07/21 15:48:27.378 ACCN SIPL 0 [Conn-8284-1000] setState: ACTIVE -> DISCONNECTED
4609 07/21 15:48:27.378 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_DISCONNECTED (1000) call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE]
EVCall=SIP-Call-4142:ACTIVE[5545586137:ACTIVE]EVConn=[SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=DISCONNECTED]
, cause=NORMAL
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE] checkCallActive
4609 07/21 15:48:27.378 ACCN SIPL 0 checkCallActive 0: isLocal=false, isMonitored=false
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE] dropped, connLen=1
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:ACTIVE[], remove connection 5545586137, last=true
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:INACTIVE[] change state to inactive, because last connection has been removed
4609 07/21 15:48:27.378 ACCN SIPL 0 [Conn-8283-5545586137] onCallConnectionDisconnected: state=ACTIVE, cause=UNKNOWN
4609 07/21 15:48:27.378 ACCN SIPL 0 [Conn-8283-5545586137] setState: ACTIVE -> DISCONNECTED
4609 07/21 15:48:27.378 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_DISCONNECTED (5545586137) call=SIP-Call-4142:INACTIVE[]
EVCall=SIP-Call-4142:INACTIVE[]EVConn=[SIP-Conn-8283, dn=5545586137, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=DISCONNECTED]
, cause=UNKNOWN
4609 07/21 15:48:27.378 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_INACTIVE call=SIP-Call-4142:INACTIVE[]
CALL_INACTIVE
EVCall=SIP-Call-4142:INACTIVE[], cause=UNKNOWN
4609 07/21 15:48:27.378 ACCN SIPL 0 Drop NON-monitored SIP-Call-4142:INACTIVE[] because it has zero connections
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:INACTIVE[] dropped, connLen=0
4609 07/21 15:48:27.378 ACCN SIPL 0 CallManager.removeCall: callIdImpl=[8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1,null,4142]
4609 07/21 15:48:27.378 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_DROPPED call=SIP-Call-4142:INVALID[]
CALL_DROPPED
EVCall=SIP-Call-4142:INVALID[], cause=UNKNOWN
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:INVALID[] checkCallActive
4609 07/21 15:48:27.379 ACCN SIPL 0 ltp8282-1000, State=DISCONNECTED: Drop Call because mode= SIP
6235 07/21 15:48:27.386 ACCN SIPL 0 SIP-Call-4142:INVALID[] removeCallListener com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
CUEGNP#
This is mandatory ??
ephone-dn 44
number 8000...
mwi on
ephone-dn 45
number 8001...
mwi off
I have not configured it to be SIP phones
I need some configuration ??
which is my mistake ??
