CUE not returning the call back to the CUCM after caller input is selected
Inbound calls route to CUE where IVR is played but when the caller input options are selected calls get terminated rather than routing back to CUCM
Call flow:
External callers dials 919-858-9772 --> FXO --> Gateway --> MGCP --> CUCM --> CTI Route Point --> CUE(IVR plays) and caller inputs --> Call terminates
Vaijanath Sonvane
Do you have correct CSS and Partitions configured for CTI Ports, CTI Route Points and Devices where call needs to be routed? When user enters input, where are you routing the call?
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
Dear Sir,
Thank You for your response.
We have the correct configuration. Even i compared both working and non working setup and both are the same.
