05-08-2013 12:28 AM - edited 03-16-2019 05:12 PM
Hi Everybody,
Here is my question ....
Environment:
- router 3845e (10.10.10.90)
- SM-SRE-700-K9 (10.10.10.91)
- CUE 8.6
- FTP, TFTP on a PC (10.10.10.245)
I am able to ping the FTP, TFTP, router, and SRE from my PC
Problem
But I am FAIL to ping the ftp/tftp(10.10.10.245) from BootLoader Mode in SRE
Anybody could help?
Thanks in Advance
Sam
Here is the router config
interface GigabitEthernet0/0
ip address 10.10.10.90 255.255.255.0
duplex auto
speed auto
interface SM4/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.10.10.91 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway 10.10.10.90
ip route 10.10.10.91 255.255.255.255 SM4/0
line 258
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
In SRE session, it always reboot itself with following error
SRE step 1 - SM registration...
Time out waiting for status: 0x00000008! Can not communicate with SECONORY Hard
Disk.
During get Native Max address ext, can not get the expected status: IDE_STAT_NO
_DRQSECONORY Hard Disk Get Native Max addr failed.ERROR - Unsupported Cisco har
d drives found
Local install not supported
Response - no installation needed (len: 422)
SRE Installation Not Needed
Restoring orignial configuration...
Updating flash with bootloader configuration.
Please wait ................... done.
*May 8 07:08:41.415: %SM_INSTALL-6-INST_RBIP: SM4/0 received msg: RBIP Registration RequestTime out waiting for status: 0x00000008! Can not communicate with SECONORY Hard
Disk.
_DRQSECONORY Hard Disk Get Native Max addr failed.Unsupported Cisco hard drives
þfound... Rebooting
Here is the VERIFY result in boot-loader
ServicesEngine boot-loader> verify ? - \
Loading disk:/bzImage ... Verifying ... done.
Starting Kernel.
Platform: sm
Verifying application level programs
Application level programs verification OK!
INIT: version 2.86 booting
mounting proc fs ...
mounting sys fs ...
mounting /dev/shm tmpfs ...
reiser root fs ...
Reiserfs super block in block 16 on 0x801 of format 3.6 with standard journal
Blocks (total/free): 122096000/122008822 by 4096 bytes
Filesystem is clean
Filesystem seems mounted read-only. Skipping journal replay.
sd 4:0:0:0: [sdb] Assuming drive cache: write through
Checking internal tree..finished
FILESYSTEM CLEAN
Remounting the root filesystem read-write...
kernel.sem = 1900 4000 32 100
vm.overcommit_memory = 1
vm.min_free_kbytes = 8192
Welcome to [1;31mCisco [0;39m Service Engine
Setting the system time from hardware clock
********** rc.aesop ****************
Populating resource values from /etc/sm_rsrc_file
Populating resource values from /etc/default_rsrc_file
Populating resource values from /etc/products/cue/default_rsrc_file
Populating resource values from /etc/products/cue/sm_rsrc_file
Push button monitor started
Processing manifests . . . . . . . . . . . complete
==> Management interface is eth0
*May 8 06:51:39.337: %SRE_SM-6-STATE_CHANGE: SM4/0 changing state from SERVICE_MODULE_STATE_FAIL to SERVICE_MODULE_STATE_STDYSkipping router communication server initialization
Skipping IOS Registration... verify requested.
Serial Number: FOC-------X
Disk /dev/sdb doesn't contain a valid partition table
INIT: Entering runlevel: 7
********** rc.verify ****************
Hardware:
- Module type: SM
- Memory (Bytes): 4113364
CPU0:
- Model: Intel(R) Core(TM)2 Solo CPU L3400 @ 1.86GHz
- Speed (MHz): 1862.116
- Cache (KB): 3072
Installed Packages:
- Installer 8.6.6.0
- Thirdparty 8.6.6
- Infrastructure 8.6.6
- CUE Voicemail Language Support 8.6.6
- Global 8.6.6
- GPL Infrastructure 8.6.6
- Voice Mail 8.6.6
- Bootloader (Secondary) 2.1.36
- Core 8.6.6
- Auto Attendant 8.6.6
Installed Languages:
- CUE Voicemail US English 8.6.6
Running CSL Installation
Installed permanent licenses:
StoreIndex: 0 Feature: VMIVR-PORT Version: 1.0
License Type: Permanent
License State: Active, Not in Use
License Count: 4 / 0
License Priority: Medium
System is being
INIT: Sending processes the TERM signal
Sending an RBCP message to IOS notifying module shutdown...
Halting ...
shutdown: sending all processes the TERM signal...
rbcp: INFO rbcp daemon output END
platform.config: INFO platform.config server output END
trace: INFO trace daemon output END
*May 8 06:52:02.181: %SRE_SM-6-STATE_CHANGE: SM4/0 changing state from SERVICE_MODULE_STATE_STDY to SERVICE_MODULE_STATE_HALT
*May 8 06:52:02.181: %SRE_SM-6-STATE_CHANGE: SM4/0 changing state from SERVICE_MODULE_STATE_STDY to SERVICE_MODULE_STATE_HALTshutdown: sending all processes the KILL signal.
shutdown: turning off swap
swapoff: No such file or directory
shutdown: unmounting all file systems
The system is hamd: stopping all md devices.
lted. Press CTRL-ALT-DEL or turn off power
sd 0:0:0:0: [sda] Stopping disk
ACPI: PCI interrupt for device 0000:01:00.0 disabled
System halted.
Here is service-module SM4/0 status
Service Module is Cisco SM4/0
Service Module supports session via TTY line 258
Service Module is trying to recover from error
Service Module heartbeat-reset is enabled
Service Module status is not available
Module resource information:
CPU Frequency: 1864 MHz
Memory Size: 2530 MB
Disk 0 Size: 500107 MB
Disk 1 Size: 1954 MB
No install/uninstall in progress
No localstore
05-11-2013 04:17 AM
Seems like defective HW.
