CUEAC - Reporting user
mcibanez
I'm configuring CUEAC and customer might be interested in using the system reports available in the Cisco Unified Reporting section.
However, they don't want the Admin user to be the one accessing the reporting section as this user has access to all the configuration section, but I haven't been able to find how to create or select a new user to access this reporting page (in fact, it only appears after logging in, so the user has access to both sections)
Anyone knows if it is possible to have a different user for accessing reporting than the one accessing the config section?
Thanks in advance,
Carmne
jamgale
Level 3
Level 3
Hi Carmen,
The only way to access to the reporting is like you descirbed, there is no way currently in the software to create a user which allows access to reporting only.
Jamie
jamgale
Level 3
Level 3
Hi Carmen,
Jamie
Many thanks, Jamie
