CUEAC Search
ouhakheme
Level 3
Level 3
Hey guys --
in CUxAC, when a search is performed on the client, it only allows you to search one field at a time, so Last Name, or Number only for example, if I type in 'Smith' in the last name field, and 'John', in the first name field, it will remove 'Smith' and only search on 'John'
It can be defeating to only search on one field with a common name on a 12,000 uesr cluster.  Any way to change this?
Let me know.
Ohamien
907ct043.
I have the same question. Has anyone already dealt with this?
I also need to adjust the length of the Title fields becaue by default it is only showing 4 characters.
I just found the answer a few days ago. It will be addressed in the next
release -- 8.6.1 coming out next month.
http://forum.arcsolutions.com/showthread.php?1665-CUEAC-8.6.1-Feature-List-and-Release-Updates
FEATURES
- Personal Directory Groups: tabbed directories, created by operators, that
are subsets of the full directory synchronized from Cisco Unified
Communications Manager
- AND Searching: search more than one directory field at the same time
