09-25-2015 04:23 AM - edited 03-18-2019 11:39 AM
We have a user who runs reports in CUIC. I granted her access to what she needs by going to CUIC, clicking the security tab > user list > edit > groups > and adding Allusers.ReportingUsers. After I do this, she has access to what she needs. The problem is that I have to add her every morning because she loses access overnight.
Any suggestions? She is the only user this happens to
Solved! Go to Solution.
09-26-2015 02:13 AM
You are running into the following bug
https://tools.cisco.com/bugsearch/bug/CSCun06699/?reffering_site=dumpcr
09-26-2015 02:13 AM
09-29-2015 06:35 AM
Ok, so there is no workaround? No patch or anything to resolve this problem?
10-01-2015 02:31 AM
This is fixed in UCCX 10.6 ES3 version, you may contact TAC for the same. Another bug with same issue covering the 10.6 and 11.0 versions
https://tools.cisco.com/bugsearch/bug/CSCus47112/?reffering_site=dumpcr
Manish
- Do rate helpful posts -
11-10-2015 07:41 AM
The answer is to not make this change in CUIC, but CCX rather. My problem was resolved by going to (In CCX) tools > user management > user view > select user you want to change > add reporting capability
Hopefully this saves someone else time!
07-07-2017 03:36 AM
please, could you mark this question as answered. Comment from Manish gave me an answer.
07-07-2017 08:18 AM
Sure thing. Glad you got an answer.
