09-06-2013 02:21 PM - edited 03-16-2019 07:15 PM
Dears,
I installed a CUP publsher version 9.1.1.100008 after that i upgraded to 9.1.1.20000-5., Now i purchased a redundant hardware server and i am trying to install CUP 9.1.1.100008 but it fails saying the publisher version is different than the subscriber version. I have downloaded the update file from the cisco website as per the attached but it is not booting by the file shown in the attached,
Any hints from where i will get the bootable file.
09-06-2013 05:01 PM
During the installation when prompted if you want to perform an upgrade select Yes, and then you will be prompted to reference the upgrade media.
HTH,
Chris
09-06-2013 05:07 PM
Bootable media is not available on CCO.
Do as Chris says, or order the bootable media via PUT
09-07-2013 06:37 AM
Alternatively you can make bootable the non bootable iso downloaded from cco following this istructions.
http://htluo.blogspot.it/2010/04/how-to-make-non-bootable-iso-image.html
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-07-2013 07:30 AM
Sure you can do that though it is not supported.
Chris
09-10-2013 01:18 PM
09-10-2013 10:34 PM
Hello
anybody canhelp me to verify the upgrade file is the valid file, i have done the upgrade on publisher by this file but now when i applying on subsciber it is showing me the no valid patch as per the above reply attachment
09-11-2013 12:03 AM
The iso file that you have with the upgrade file on it, why don't you stick it in the data store on your UCS and mount it to the DVDrom of your virtual machine, must easier and more reliable than screwing around with upgrade from sFTP.
Please remember to rate useful posts, by clicking on the stars below.
09-11-2013 02:02 AM
Dear Dennis,
It is not a bootable file to boot from datastore, i have to show upgrade path and there are 3 option for upgrade file ftp,sftp or local DVD on UCS machine, I dont have a DVD on server thats the reason i am choosing ftp or sftp.
09-11-2013 02:09 AM
You do not need sftp/ftp When you select the local DVD, and select datastore ISO file under the cd/dvd drive 1 under the CUCM virtual machine.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
09-11-2013 02:12 AM
The file that you have in the FTP folder is a .iso file. You should use winzip/winrar or any other software which can extract the .sgn file from this ISO file and then try using the FTP path.
Ideally, you could point your VMWare to use the ISO image as the CD/DVD, but considering you would be doing it to point the server to the bootable install file for the 9.1.1 that you have, I dont think you can do the same.
09-11-2013 02:42 AM
You need to check which folder your user is using on the FTP server. The file the install is trying to download needs to be on that folder. You can't just put the file anywhere. This is why you are getting the error
09-11-2013 06:33 AM
Dear
Aokan,
I have attached all the screenshot in previous mail can u confirm whther these are correct path ??
09-11-2013 06:39 AM
You need to do e ff.
1. Under the c/prog files/freetftpd
2 create a step folder
3. Create a folder for user abc
4. In abc folder put the installation iso
In your directory path on cups server use . (Dot) this will take cups server to the home directory for the user...ensure the home directory on freeftpd is set to the default
09-11-2013 06:41 AM
If you define. Custom directory on ftpd server...as you have in your diagram at sould work too. Ensure the directory path on cups server is pointing to the user abac home directory
