09-24-2014 07:33 AM - edited 03-17-2019 12:17 AM
On my CUPS system (9.1) every minute in the Notifications page in cupadmin, the message:
"An audit is in progress and users are automatically being moved to this node."
There's nothing wrong with the cluster state (Well,not according to Cluster Topology.) Diagnostics->System Dashboard says users are due to be moved back.
Should I do anything, other than just delete these messages? They've been going on for some time now - and there's not many users configured on CUPS at the moment.
GTG
01-23-2015 12:30 PM
I ended up logging a TAC case with this. It turns out that there is a bug in CUPS 9.1. If you change the presence domain the database becomes corrupt (BugId CSCuq16135 ). The only fix is for TAC to log on and manually fix the database.
GTG
01-23-2015 01:54 PM
We hit the exact same issue, the exact same bug, but had an additional manifestation as described in the bug details - users not able to be migrated from inactive to active.
TAC got in and fixed the database and it fixed the spurious logs for us, too. Thanks for the feedback!
