I have been having a play with sending SQL queries to CUCM using cURL and SOAP. The query side of it seems to work find. However I'm now trying to send an insert and I'm getting returned: <faultstring>The Insert privilege is required for this operation.</faultstring><detail><axlError><axlcode>-275</axlcode>
If I run the same insert query from CUCM CLI it works fine.
I'm not sure if I need to allocate any specific permissions to the CUCM app user account to give this privilege?
Thanks in advance.
Solved! Go to Solution.
This error (<faultstring>The Insert privilege is required for this operation.</faultstring><detail><axlError><axlcode>-275</axlcode>) is due to this reason: You might be sending the INSERT request with the executeSQLQuery.
Try sending the same request using executeSQLUpdate. It works.
Thank You
Thank You
Many thanks for the reply. This resolved the problem.
