Custom directory - AnyConnect for Cisco VPN Phone
Mavinktul
Beginner
Beginner
VPN Phones are unable to access the phone services setup, the directory is an external directory source URL inside the corporate network and not CUCM server
This works on the internal phones and never worked on the VPN phone
can you please confirm if the traffic to this xternal directory source URL will pass via ASA then CUCM as a proxy to external directory source URL inside the corporate network? or Directly from ASA to external directory source URL inside the corporate network. Needed help understanding traffic flow
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
CUCM is NOT used as a proxy for external directories/services which the phone is configured to use. The phone would reach directly to where the resource is.
java
if this helps, please rate
Thank you Jamie.
On the VPN phone however we are getting an error 'Host not found' with the FQDN of the directory and also doesn't work with the IP address either. PCAP from ASA inside interface showed no traffic related to directory service, Could you please suggest what can we check to start the troubleshooting
Recognize Your Peers
