Custom extension for Messages Button on 8845 using SIP
cainram
I have used SEPmac.cnf.xml files to provision my 8845s. I have BLFs working, custom wallpaper, lineMode 1 enabled, etc. So I've got a good handle on how to use the XML structure to get the behavior I'm looking for out of these phones. I cannot, however, get the physical Messages button to dial my PBX's check messages extension: *97. I have used <messagesNumber>VOICEMAIL EXTENSION</messagesNumber> and also tried <messagesURL></messagesURL> to no avail. I also switched back to <lineMode> 0 to see if that was the issue and it was not. I get the 'Messages not available' screen on the phone's display and my PBX indicates there is no attempt to connect to the extension.
Many thanks in advance
Prolixium
Were you able to find a solution?  I'm running into the same issue on 8861s and ran through the same t-shooting steps as you did but when the messages button is pressed it results in no network activity and shows messages not available.
