09-21-2010 04:42 AM - edited 03-16-2019 12:54 AM
hi all,
Im trying to modify the accounting-tempalte in CCME 7.1 for get the customize reports .. i made changes & if i do sh call accounting-template voice i have following msg !!! & in reports im still getting the complete detail record
CCME#sh call accounting-template voice
CDR template sample is running
url: tftp://10.70.200.32/sample.cdr
The last load was successful.
h323-call-origin
h323-call-type
h323-connect-time
h323-disconnect-time
h323-gw-id
h323-remote-address
h323-setup-time
h323-voice-quality
charged-units
disconnect-text
codec-bytes
gw-rxd-cdn
gw-rxd-cgn
gk-xlated-cdn
gk-xlated-cgn
gw-collected-cdn
call-id
calling-party-category
charge-number
account-code
Totally 20 attrs defined.
CDR template relaod is not running
url: sample.cdr
Last load returned errno=250, Network is down
CCME#
CCME#
CCME# call accounting-template voice sample tftp://10.70.200.32/sample.cdr
CCME #call accounting-template voice relaod sample.cdr
my configuration for ftp is below, can any body tell me is that right configuration to send reports on External FTP Server
gw-accounting aaa
gw-accounting syslog
gw-accounting file
primary ftp \\10.70.200.6\ccme\cdr username Administrator password SRV@bipa
maximum buffer-size 15
maximum retry-count 3
maximum fileclose-timer 300
maximum cdrflush-timer 245
cdr-format compact
03-18-2013 04:04 AM
Hi Anis,
Im trying to configure cme over radius for billing app for the first time. apparently below is what i get -
CDR template sample is not running
url: tftp://172.16.126.10/sample.cdr
url: sample.cdr
My radius based config looks like this -
aaa new-model
aaa authentication login h323 group radius
aaa authorization config-commands
aaa authorization exec default if-authenticated
aaa authorization exec h323 group radius
aaa authorization network default group radius
aaa authorization configuration default group radius
aaa accounting connection h323 start-stop group radius
aaa accounting system default start-stop group radius
aaa accounting resource default start-stop group radius
gw-accounting aaa
acct-template sample
radius-server host 172.16.126.10 auth-port 1612 acct-port 1616
radius-server host 172.16.126.10 auth-port 1645 acct-port 1646
radius-server key cisco
radius-server vsa send accounting
radius-server vsa send authentication
call accounting-template voice sample tftp://172.16.126.10/sample.cdr
Is it possible for you to share your configuration. Thanks a lot in advance.
NB: What is the status of your problem?
Shabeeb
