07-30-2020 03:17 AM
Hello All,
Hope you are all well!
May I know if i can access self care portal over a customized port, for instance:
https://cucmipaddress:1616/ucmuser
Use case is to restrict unathorized access to CallManager administration page.
Thanks in advance
Solved! Go to Solution.
07-30-2020 06:39 AM
No way to do that on CUCM, so you need to do it at network level.
07-30-2020 05:33 AM
You can't customize the port
07-30-2020 06:05 AM
07-30-2020 06:39 AM
07-30-2020 07:42 AM
