Walkthrough Wednesdays
297
@Syed
Participant
Customized port for CUCM Self Care portal
Hello All,
Hope you are all well!
May I know if i can access self care portal over a customized port, for instance:
https://cucmipaddress:1616/ucmuser
Use case is to restrict unathorized access to CallManager administration page.
Thanks in advance
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
No way to do that on CUCM, so you need to do it at network level.
java
if this helps, please rate
4 REPLIES 4
Jaime Valencia
You can't customize the port
java
Thanks Java!
Could you suggest an alternate way to restrict CUCM admin page.
Jaime Valencia
java
Thank you as always
Content for Community-Ad
Spotlight Awards 2021
