CUWL for Unity Connection with Domino Question
Aaron Dhiman
Level 2
Level 2
The Unity Connection 8 System Requirements state that a Server License is required to use ViewMail with Lotus Notes:  http://cio.cisco.com/en/US/docs/voice_ip_comm/connection/8x/requirements/8xcucsysreqs.html#wp137133
Is this included with the CUWL Option "UNITYCN8-USR-D" (One Unity Connection 8.x User - All user Features - Domino) or with "UNITYCN8-7845-D" (Unity Connection 8.x for 7845 - Domino)?  Or is some other part required?
Rob Huffman
Hi Aaron,
The "server" license that is referenced in the release notes is ordered via this part#;
UNITYCN8-7845-D
or
UNITYCN8-HA-7845-D Unity Connection 8.x HA for 7845 - Domino
Cheers!
Rob
Cool, thanks Rob.  I don't see the part "UNITYCN8-HA-7845-D" as an option for CUWL Pro licensing, only the "UNITYCN8-7845-D" part.  Is HA included with UNITYCN8-7845-D if ordered under CUWL?  We would be getting the preloaded app server (MCS7845I3-K9-UCC1) if that makes a difference.
Also, do I need one of the UNITYCN8-7845-D for each Unity Connection server, or just for each Unity Connection cluster?
I found the part as an optional add-on under CUWL (L-UNCN8-HA-7845-D).  Does this look right for a system with two Unity Connection clusters each with HA?  Each cluster should support 500 ports.  The system should integrate with Lotus Domino with full feature support for 7500 users.
MCS7845I3-K9-UCC1 CUCxn 8.0 MCS-7845-I3,4x300 HDD,8GB RAM,Quad-Cores       4
  UNITY-PWR-US Power Cord - US        8
UNITYCN8-USR-D One Unity Connection 8.x User - All user Features - Domino        7500
UNITYCN8-7845-D Unity Connection 8.x HA for 7845 - Domino - eDelivery                     2
L-UNCN8-HA-7845-D Unity Connection 8.x HA for 7845 - Domino - eDelivery                 2
UCXN-MAXP-80-UWL Unity Connection 8.0 Max ports for CUWL only                           4
