04-30-2011 03:15 AM - edited 03-16-2019 04:44 AM
Hi .
Good Day , can anyone explain to me what is this about ? In What situation or environment we need this ?
04-30-2011 10:50 AM
CUWL "simplifies ordering", it also helps partners sell more than just callmanager and unity. CUWL is only used for ordering, there's no actual CUWL licenses. When you order CUWL you still get licenses for each product individually. Here is a good place to start:
Typically you sell CUWL standard and CUWL professional licenses. If a customer just wants callmanager and unity connection voicemail, you can either sell them separately which will be slightly lower cost, or sell CUWL standard licenses which will include callmanager and unity connection, and some additional stuff, specifically, presence server (CUPS) license and personal communicator (CUPC) license. This also means that you need to sell a separate server for CUPS (unless you are virtualizing).
One requirement to keep in mind with CUWL is that you have to buy 3-years of UCSS for CUWL (EDU and GOV can buy 1-year). You can still buy 1 year of ESW smartnet, but you do need 3 years of UCSS.
05-01-2011 10:04 PM
Hi Roman.
thanks for your information, very useful. would you be able to share with me about the fellowing ?
IF my customer wanna buy additional phones and the CallManager version as below.
2. CallManager v5 to CallManager v7
3. Callmanager v8
Thanks .
Regards.
05-01-2011 10:22 PM
For CM4 it's SW-CCM-UL-7942, for CM5> if they don't already have enough DLU licenses in callmanager, you need to buy more DLU's. 7942 uses 4 DLUs. The smallest number of DLU's you can order is 10: LIC-CM-DL-10. For CM8 you can also order UCL Enhanced user: LIC-CUCM-USR.
05-01-2011 10:34 PM
Hi Roman.
Thanks for your information . how about this 2 ? what is this for ?
