I recently installed BE6K with CUCM, CUC, CUP version9.1
The bundle came with CUWL standard (9.0) x 25 license
I installed 16 x Cisco8961 handsets(SIP) with extensions 100 - 115 and assigned the phone to each user
I programmed 16 x device profile with extensions 200 - 215 for extension mobility and associated device profile to each user
I programmed 16 x CSF devices with extensions 200 - 215 for Jabber desktop and assocuated the csf to each user
Under user configuration each user selects the 2XX extension as the Primary Extension
Then I checked the ELM, above configuration using 32 x Enhanced (9.0), I need to buy 7 more license....
For my understanding if I assigned one phone and one csf to the same user it should only use one CUWL license.
Am I wrong?
