12-12-2007 08:03 AM - edited 03-15-2019 07:45 AM
Good afternoon,
I have new Cisco IP Phone 7941, I have configured on my cisco 2851, CME 4.1.
But on router I have firmware on flash SCCP41.8-2-2SR1S not 8-2-1S. The phone didn't upgrading with this firmware, and reboot every time and searching firmware 8-2-1S.
Normally router decide which firmware to upgrading phone, but not in this case.
See log (console on phone) and picture (bad quality) in attachment, if you have any idea, thanks.
12-12-2007 11:04 AM
Hi Fabien,
If you have all the correct files loaded on Flash, can you try;
telephony-service
load 7941 SCCP41.8-2-2SR1S
Hope this helps!
Rob
12-13-2007 04:10 AM
This is the configuration..
tftp-server flash:apps41.8-2-2ES1.sbn
tftp-server flash:cnu41.8-2-2ES1.sbn
tftp-server flash:dsp41.8-2-2ES1.sbn
tftp-server flash:SCCP41.8-2-2SR1S.loads
tftp-server flash:cvm41sccp.8-2-2ES1.sbn
tftp-server flash:jar41sccp.8-2-2ES1.sbn
telephony-service
Fabien
12-13-2007 05:29 AM
Hi Fabien,
It seems to me you might be missing this in flash;
tftp-server flash:term41.default.loads
Phone Firmware Files
For Java-based IP phones, such as the Cisco Unified IP Phone 7911, 7941, 7941GE, 7961, 796GE, 7970, and 7971, the firmware consists of multiple files including JAR and tone files. All of the firmware files for each phone type must be downloaded the TFTP server before they can be downloaded to the phone.
The following example shows a list of phone firmware files that are installed in flash memory for the Cisco Unified IP Phone 7911:
tftp server-flash:SCCP11.7-2-1-0S.loads
tftp server-flash:term06.default.loads
tftp server-flash:term11.default.loads
tftp server-flash:cvm11.7-2-0-66.sbn
tftp server-flash:jar11.7-2-0-66.sbn
tftp server-flash:dsp11.1-0-0-73.sbn
tftp server-flash:apps11.1-0-0-72.sbn
tftp server-flash:cnu11.3-0-0-81.sbn
However, you only specify the filename for the image file when configuring Cisco Unified CME. For Java-based IP phones, the following naming conventions are used for image files:
SCCP firmware - TERMnn.xx-y-z-ww or SCCPnn.xx-y-zz-ww, where n represents the phone type, x represents the major version, y represents the major subversion, z represents the maintenance version, and w represents the maintenance subversion.
The following example shows how to configure Cisco Unified CME so that the Cisco Unified IP Phone 7911 can download the appropriate SCCP firmware from flash memory:
Router(config)# telephony-service
Router(config-telephony)#load 7911 SCCP11.7-2-1-0S
SCCP: Upgrading or Downgrading Phone Firmware Between Versions
To downgrade or upgrade firmware versions on a Cisco Unified IP phone running SCCP, perform the following steps.
Prerequisites
Phone firmware for Cisco Unified IP phones to be connected to Cisco Unified CME, including all versions required during an upgrade or downgrade sequence, must be loaded in the flash memory of the TFTP server from which the phones download their configuration profiles.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. load phone-type firmware-file
5. create cnf
6. end
Hope this helps!
Rob
12-13-2007 07:14 AM
Ok that's fine, I forget one line :
tftp-server flash:term61.default.loads
telephony-service
sh flash :
46 642 Dec 10 2007 14:10:56 +01:00 term41.default.loads
47 642 Dec 10 2007 14:11:06 +01:00 term61.default.loads
93 2453223 Dec 10 2007 12:38:26 +01:00 apps41.8-2-2ES1.sbn
94 435144 Dec 10 2007 12:38:34 +01:00 cnu41.8-2-2ES1.sbn
95 509001 Dec 10 2007 12:38:52 +01:00 dsp41.8-2-2ES1.sbn
96 642 Dec 10 2007 12:39:08 +01:00 SCCP41.8-2-2SR1S.loads
97 2141085 Dec 10 2007 12:42:46 +01:00 cvm41sccp.8-2-2ES1.sbn
98 229364 Dec 10 2007 12:42:58 +01:00 jar41sccp.8-2-2ES1.sbn
debug tftp events :
261382: Dec 13 16:04:10: TFTP: Server request for port 4565, socket_id 0x47F97F00 for process 261
261383: Dec 13 16:04:10: TFTP: read request from host CME_IP_ADDRESS(4565) via FastEthernet0/0
261384: Dec 13 16:04:10: TFTP: Looking for SCCP41.8-2-1S.loads
261385: Dec 13 16:04:10: TFTP: Sending error 1 No such file
261386: Dec 13 16:04:13: TFTP: Server request for port 4566, socket_id 0x47EBEA34 for process 261
261387: Dec 13 16:04:13: TFTP: read request from host CME_IP_ADDRESS(4566) via FastEthernet0/0
261388: Dec 13 16:04:13: TFTP: Looking for SCCP41.8-2-1S.loads
261389: Dec 13 16:04:13: TFTP: Sending error 1 No such file
Sorry, hope you can help me.
12-13-2007 10:52 AM
please configure:
