09-11-2014 08:11 PM - edited 03-17-2019 12:08 AM
Hi there,
I would like to know if I implement a 10 channel using a E1 ISDN service, what will be the interface number for the D channel. For example if I implement a full E1 ISDN, the D channel is normally on Serial0:0:15
Thanks Guys
Solved! Go to Solution.
09-11-2014 09:36 PM
D-channel will remain the same even for partial PRI.
http://www.cisco.com/c/en/us/td/docs/ios/12_2/dial/configuration/guide/fdial_c/dafchant.html
"The B channel numbers range from 1 to 31; channel 16 is the D channel for E1. Corresponding serial interfaces numbers range from 0 to 30. In commands, the D channel is interface serial controller-number:15. For example, interface serial 0:15"
Manish
09-11-2014 09:36 PM
Manish
