Date Format on IP Phone with CME 7.1
karamalomari
Dear all,
I have a request to change the Date Format on the Cisco IP Phones from dd/mm/yy to dd/mmm/yy
Example: Change it from 10-11-10  to 11-Nov-10
Is this possible? if yes How and what are the steps to achive it?
Thank you.
6 Replies 6
kvancoil
You can change the date format using the below command:
GW (config-telephony)#date-format ?
  dd-mm-yy  Set date to dd-mm-yy format
  mm-dd-yy  Set date to mm-dd-yy format
  yy-dd-mm  Set date to yy-dd-mm format
  yy-mm-dd  Set date to yy-mm-dd format
However I am afraid the format you are looking for is not available.
Cheers,
Kristof
The format that I am looking for is DD-MMM-YY and not the default ones under the GW (config-telephony)#date-format ?
So my question is can we achieve the DD-MMM-YY format?
Thank you
As clearly indicated above already:
No.
Not possible indeed (I also checked in 151-2.T2); if this is really important you can ask your account team to submit a product enhancement request for this.
Cheers,
Kristof
dear all,
I would like to thank all of you for the feedback.
yours,
Karam
Walter Solano
Level 7
Level 7
Also, After you change the date/time format you need to recreate the configuration files "no create cnf-files" and "create cnf-files", please reset the IP phone after that so they can load the new configuration files
