DB service is down, after changing the security password CSCth87452
today i got aware of Bug-ID CSCth87452 with the above Title. Does anybody know if this bug is fixed in CUCM/CUC Version 9.1.1(a)? The Fixed-In INformation tells about some 8.X and 1.0.X Version, but nothing about 9.X Versions.
Any help is welcome!
/Robert
2 Accepted Solutions
Jaime Valencia
It doesn't show here
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_1_1/CUCM_BK_RD7D4696_00_release-notes-for-cisco-unified_chapter_0101.html
But I also don't see 9.X as affected
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Rob Huffman
Hi Robert,
I have never seen this in any release beyond the two listed 8.0 &
8.5(0) builds so I really don't think there is any reason to worry. And
I'm the ultimate "Paranoid" when it comes to this stuff
The  1.0(0.98000.42) would be an internal only Cisco overnight
build as per the .98xxx in the versioning so it doesn't reflect
anything that should be running out in the enterprise.
I've scoured the forums here for anybody hit by this that wasn't
running the versions I listed above and there were none.
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
Jaime Valencia
java
java
Rob Huffman
Hi Robert,
Java is most correct here (+5). This bug manifested in 8.0 & early 8.5 builds only.
CSCth87452 - DB service is down, after changing the security password
Description
A Cisco DB service will not start after changing security password.
Observed  on CUCM  / Unity Connection servers running 8.0.x version and when  security password is changed via console using password recovery  procedure.
Contact Cisco TAC to implement the work around.
Details
First Found in:                          (2)
8.0(3),8.5(0.96041.3)
Status:
Fixed
Last Modified:
May 23,2013
Fixed in:                          (5)
8.5(1.10000.26),8.5(0.98000.9),8.5(0.98000.17)
8.0(3.22018.1),1.0(0.98000.42)
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
2 - severe
Cheers!
Rob
- The Clash
Java, Rob,
if i did understand you correctly 9.1.1(a) should not be affected. What makes me unsure is that 1.0(0.98000.42) is explicitly mentioned as a Fixed Version. This makes me think that not all Versions above 8.5 will have the fix.
/Robert
Rob Huffman
Hi Robert,
Cheers!
Rob
- The Clash
