02-07-2012 11:53 PM - edited 03-16-2019 09:28 AM
We have a new Cisco 3945E with IOS Version 15.1(4)M1 and IOS Image c3900e-universalk9-mz.SPA.151-4.M1.bin.
I'm trying to configure our SIP Trunk to work on this new machine, but it's not working. I'm calling from our other machine using ISDN to one of the configured numbers on the 3945. See attachments for config and debugs. I hear no ringback tone from the phone I'm calling from and it just disconnects after a few seconds.
Our SIP Trunk works just fine on our Cisco 3825 (IOS 12.4) and 3925(IOS 15.0) using the same configuration as in the attachments. I just can't figure out what else is missing or what is wrong with the setup in the 3945E.
If you need other debugs, please ask.
Thanks.
02-08-2012 11:50 AM
Hi Grant Bagdasarian,
Do you get the solution for the issue of "VXML: Cisco-Data element behavior"? I encounter the same problem.
02-09-2012 11:19 PM
Could this be a DSP problem?
cmuc03#sh dspfarm
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
