09-28-2022 01:31 AM
Hello community ,
I'm debugging a gateway to verify if the international call pass or no , can you help with an output or anything else so I can verify ?
09-28-2022 02:17 AM
Hi, what do you mean with your question?
If you have problems with a call, make a test call and post the output of the debugs here, so other people can help you analyze it.
09-28-2022 03:52 AM
I hope your question is how to debug
if it’s a isdn pri line use debug isdn q931
debug voice ccapi inout also give more information
if it’s a sip trunk use debug ccapi messages
09-29-2022 07:53 AM
You can also post your debug here along with the calling party information and the international number they are trying to dial. We can help take a look.
Maren
10-03-2022 08:10 AM
dial-peer voice 56 voip
--More-- description * Appel InterNational PSTN via Trunk SIP *
translation-profile outgoing outgoing-PSTN
preference 1
destination-pattern ^9T$
session protocol sipv2
session target ipv4:xx.xx.xx.xx
voice-class codec 1
dtmf-relay rtp-nte
no vad
09-29-2022 08:25 AM
Hello , The problem was resolved after debugging the gateway , we haven't observed anything special so we conclude that the problem is due to the operator who is blocking the international call.
Thanks guys !
