07-03-2016 03:09 AM - edited 03-17-2019 07:25 AM
i keep trying to enter the command "debug isdn q931" and "terminal monitor" but it isnt showing incoming calls information , im not sure if im missing a third command or there is an issue with my voice gateway , it is a h323 VG btw?
Solved! Go to Solution.
07-03-2016 03:43 AM
Put these two commands "logging console" & "logging monitor" under global config mode and then check.
Suresh
07-03-2016 03:43 AM
Suresh
07-03-2016 03:48 AM
i entered those two "logging on" and "logging monitor debugging" and it worked!
07-29-2020 12:27 PM
I know this is an older post but also check for hung VTY sessions.
sh users
disconnect ssh vty 1
disconnect ssh vty 2
disconnect ssh vty 3
etc......
