debug command not showing anything on Voice gateway 2811?
baselzind
Level 6
Level 6
i keep trying to enter the command "debug isdn q931"  and "terminal monitor" but it isnt showing incoming calls information , im not sure if im missing a third command or there is an issue with my voice gateway , it is a h323 VG btw?
Suresh Hudda
Put these two commands "logging console" & "logging monitor" under global config mode and then check.
Suresh
Suresh Hudda
Suresh
i entered those two "logging on" and "logging monitor debugging" and it worked!
jclemence
I know this is an older post but also check for hung VTY sessions.
sh users
disconnect ssh vty 1
disconnect ssh vty 2
disconnect ssh vty 3
etc......
