Debug FAX issues
mcecilia
Beginner
Beginner
Hello Sirs,
I need to debug T30 messages in VG224, in both sides of this architecture:
FAX -- VG224 -- MGCP -- CUCM -- CISCO 2911 -- PRI -- PSTN -- SIP TRUNK -- CUCM -- MGCP -- VG224 -- FAX
I use the command "debug fax relay t30 all-level-1" and I do not receive any info about T30 messages.
I am connected to VG224 using a console cable, and to the other using telnet with "terminal monitor" enabled.
Can you help?
Try to follow these instructions:
MGCP VoIP Gateway
Configuring your Cisco VoIP Gateway to ensure that your gateways are properly configured to support T.38
fax relay protocol. To enable CA controlled mode in cisco router, configure the following:
Router(config)# no mgcp fax t38 inhibit
Router(config)# mgcp package-capability fxr-package
However, the following are items to verify if the solution is not working:
The fxr-package must be visible under "MGCP supported packages" when running the command SHOW MGCP. If it is  not present you have to add it with the command "mgcp package-capability fxr-package" and reload the gateway after.
The presence of the following two commands will remove the fxr-package from the gateway config after reload:
o ccm-manager config server [IP addr]
You will have to configure the fxr-package as default-package and reload mgcp gateway again.
The following commands can be executed:
o no ccm-manager fax protocol cisco - Disable the Cisco fax protocol
o no mgcp fax t38 ecm - To enable or disable ECM (Error Correction Mode)
o mgcp fax rate XXXXXX -To configure the maximum fax rate
o mgcp fax t38 ls_redundancy X -To configure Low Speed fax redundancy
o mgcp fax t38 hs_redundancy X -To configure High Speed fax redundancy
Add fax config of VG and 2911.
Regards.
Daniele Giordano
Collaborator
Collaborator
"debug fax relay t30 all" works if fax is transported with T.38 protocol. If you use fax passthrough, debug doesn't work.
What protocol is configured?
Regards.
It seems it should go into T38, but when I run "show voice call summary during the fax transmision, I do not see it, only PCMA and PCMU".
This is my actual "show mgcp":
jb3-2-vg#show mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 192.168.69.13 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay voip codec all mode out-of-band
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711alaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 1000 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31
MGCP default package: line-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
                         hs-package rtp-package atm-package ms-package dt-package
                         mt-package sst-package fxr-package md-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is 7200 bps
MGCP T.38 Fax is ENABLED
MGCP T.38 Fax ECM is ENABLED
MGCP T.38 Fax NSF Override is DISABLED
MGCP T.38 Fax Low Speed Redundancy: 0
MGCP T.38 Fax High Speed Redundancy: 0
MGCP Fax relay SG3-to-G3: ENABLED
MGCP Fax relay ANSam suppression: DISABLED
MGCP control bind :DISABLED
MGCP media bind :DISABLED
MGCP Upspeed payload type for G711ulaw: 0,  G711alaw: 8
MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97
MGCP Static payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.726-32K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Dynamic payload type for NSE is 100
MGCP Dynamic payload type for NTE is 99
MGCP rsip-range is enabled for TGCP only.
MGCP Comedia role is NONE
MGCP Comedia check media source is DISABLED
MGCP Comedia SDP force is DISABLED
MGCP g729 variants use static payload type and contain annexb in SDP
MGCP Guaranteed scheduler time is DISABLED
MGCP Disconnect delay error recovery DISABLED
MGCP DNS stale threshold is 30 seconds
jb3-2-vg#show mgcp
The problem was finally in the Gateway that holds the PRI, that was not configured for T38. Then, VG224 didn´t go to T38.
MGCP VoIP Gateway
Regards.
