debug isdn q931 equivalent for voice E1
JacobMunson
is there an equivalent command for testing voice E1's as debugh isdn q931for PRI's?
6 Replies 6
Aaron Harrison
Yes there is - it's 'debug isdn q931'
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
paolo bevilacqua
If you mean E1 R2 (CAS), that is "debug vpm signal".
To tell you the truth I am not really sure what kind of E1 it is. The only configuration in the router is this.
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
This is my first time working with an E1 so thanks for any help.
Then you have E1 R2. You can read about E1 R2 configuration and troubleshooting from here:
http://www.cisco.com/en/US/partner/tech/tk652/tk653/technologies_configuration_example09186a00800ad389.shtml
At the bottom of the doc, you'll find more interesting documentation.
Hope it helps, please rate if it helps.
Kind regards,
- Adrian.
hmm I can't seem to access that link i get a forbidden File or Application worning.
Here is in PDF.
Kind regards,
- Adrian.
