07-08-2015 06:47 PM - edited 03-17-2019 03:35 AM
07-09-2015 12:04 AM
From the logs I can see that you are using T1 PRI. By default Cisco PRI routers use descending channel selection. This means that channels 30 is your 1st channel which the IOS router is using to communicate with your telco. Channel 35 is the channel selected by your telco to signal your router. Usually the telcos use NFAS to provide large pool of channels.
07-09-2015 11:14 AM
But there are only 23 channels on each PRI. NFAS is not implemented here. I must be missing something.. how can 30 and 35 be used on a 23 channel PRI?
07-09-2015 11:54 AM
Can you share the output of show inventory from your router?
07-09-2015 12:12 PM
sh inventory
NAME: "CISCO3925-CHASSIS", DESCR: "CISCO3925-CHASSIS"
PID: CISCO3925-CHASSIS , VID: V02, SN: FTX...
NAME: "Cisco Services Performance Engine 100 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 100 for Cisco 3900 ISR"
PID: C3900-SPE100/K9 , VID: V06 , SN: FOC...
NAME: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-4MFT-T1/E1 , VID: V01 , SN: FOC...
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128 , VID: V01 , SN: FOC...
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC , VID: V04 , SN: QCS...
NAME: "C3900 AC Power Supply 2", DESCR: "C3900 AC Power Supply 2"
07-09-2015 03:32 PM
This is really interesting, could you please post the following outputs:
1. sh isdn status
2. sh run from the router
07-09-2015 03:53 PM
sh isdn status
Global ISDN Switchtype = primary-ni
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/2:23 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = primary-qsig
**** Master side configuration ****
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 70
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN Serial0/0/3:23 interface
dsl 1, interface ISDN Switchtype = primary-qsig
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
Number of L2 Discards = 0, L2 Session ID = 164
Total Allocated ISDN CCBs = 0
sh run
Building configuration...
Current configuration : 6543 bytes
version 15.2
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
hostname vg1...
boot-start-marker
boot system flash:c3900-universalk9-mz.SPA.152-4.M7.bin
boot system flash:c3900-universalk9-mz.SPA.152-4.M6a.bin
boot-end-marker
card type t1 0 0
logging buffered 8000000
enable secret 5 $1$
aaa new-model
aaa group server tacacs+ tacgroup
server 172.
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring 2 Sun Mar 2:00 2 Sun Nov 2:00
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
network-clock-select 3 T1 0/0/2
network-clock-select 4 T1 0/0/3
ip cef
no ipv6 cef
isdn switch-type primary-ni
voice-card 0
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
voice translation-rule 1
rule 1 /^42/ //
voice translation-profile Voice
translate called 1
license udi pid C3900-SPE100/K9 sn FOC18349XQG
hw-module pvdm 0/0
redundancy
controller T1 0/0/0
shutdown
cablelength long 0db
controller T1 0/0/1
shutdown
controller T1 0/0/2
pri-group timeslots 1-24 service mgcp
description Nortel Loop 40
controller T1 0/0/3
description Nortel Loop 41
class-map match-any AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-any AutoQoS-VoIP-Control-Trust
match ip dscp cs3
match ip dscp af31
policy-map AutoQoS-Policy-Trust
class AutoQoS-VoIP-RTP-Trust
priority percent 70
class AutoQoS-VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
interface Embedded-Service-Engine0/0
no ip address
description To LAN
ip address 172.30.189.101 255.255.255.0
ip pim sparse-dense-mode
duplex auto
speed auto
service-policy output AutoQoS-Policy-Trust
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/2:23
description To-Nortel-Loop-40
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn protocol-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/3:23
description To-Nortel-Loop-41
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 172.
logging trap debugging
logging host 172.
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/2:23
voice-port 0/0/3:23
ccm-manager fallback-mgcp
ccm-manager redundant-host ucmsub2
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
mgcp
mgcp call-agent ucmsub1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate domain-name
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
