01-30-2010 08:57 AM - edited 03-15-2019 09:15 PM
12.4.24T2 with CME7.1/H323
SDCVWRT-5204-2#debug isdn q931
Jan 30 16:37:55.915: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x3 is 0x2 0x1, Calling num 2123805999
Jan 30 16:37:55.915: ISDN Se0/0/0:23 Q931: Sending SETUP callref = 0x00C0 callID = 0x8041 switch = primary-5ess interface = User
Jan 30 16:37:55.915: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x00C0
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x2180, '2123805999'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '9044914588'
Jan 30 16:37:55.979: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80C0
Cause i = 0x82E418 - Invalid information element contents
SDCVWRT-5204-2#show run | begin dial-peer
dial-peer voice 91904 pots
destination-pattern 91..........
incoming called-number .
direct-inward-dial
port 0/0/0:23
forward-digits 10
dial-peer voice 4 voip
destination-pattern 4...
session target ipv4:10.89.224.1
codec g711ulaw
Below is what telco is saying….anyone else seen this?
3109:
The switch received a Q.931 SETUP message from the customer premises equipment (CPE) on a primary rate interface (PRI) D-channel, but the message contained an invalid channel identification information element (IE).
2019:
The switch transmitted an information frame and did not receive an acknowledgement in T200 time units from the far end. The switch proceeded to poll the far end with a LAPD receiver ready (RR) or receiver not ready (RNR) frame. The RR or RNR was re-transmitted N200 times (with each RR or RNR retransmitted every T200 time units) and got no response from the far end. An RR or RNR frame should be the response
01-30-2010 09:09 AM
Try:
interface se0/0/0:23
isdn map address . plan unknown type unknown
Also, you should send 11 digits for LD calls.
Blaming L2 is completely off-base.
01-30-2010 09:23 AM
I changed type/plan and tested with both 10 digits and 11 digits and still getting same error message. Any other ideas?
SDCVWRT-5204-2#
Jan 30 17:20:58.011: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x3 is 0x0 0x0, Calling num 2123805999
Jan 30 17:20:58.011: ISDN Se0/0/0:23 Q931: Sending SETUP callref = 0x00C5 callID = 0x8046 switch = primary-5ess interface = User
Jan 30 17:20:58.011: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x00C5
Standard = CCITT
Calling Party Number i = 0x0080, '2123805999'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '19043383245'
Jan 30 17:20:58.075: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80C5
01-30-2010 09:32 AM
The setup message is 100% correct. The switch is either misconfigured or faulty.
They may try to blame it back to you as telcos always do, but stand firm, ask them to come on premises and place a call using their test equipment, and be shown the trace.
01-30-2010 09:25 AM
01-31-2010 06:46 PM
have you checked you telco is using: primary-5ess as switch type ?? although it may be used most common is NI.
02-01-2010 01:17 AM
Efrain,
setup messages from the router are identical for any type of switch.
