Hi all,
I have setup as follows:
PSTN-----CUBE-----CUCM(1,2,3)------Jabber-controled IP Phone
On cube I have three dial peers shooting at CUCMs 1,2,3, with three preferences and SIP keepalives to CUCM
I noticed when I decline incoming call (pressing red button) on IP Phone, call stops on the first pressing (as I later found out, this decline sends "486 Busy Here" to CUBE. This behaviour is OK and expected.
However, If I press the red button on Jabber client controlling the given phone, I get two more iterations of ringing, meaning I have to decline it (press button) three times altogether.
On CUBE, I see these three tries are three dial peers (to CUCMs1,2,3), and every time I press the red button, CUBE gets "403 Forbidden" from CUCM.
Obviously huntstop on dial peer is not an option, because, while it cures above condition, it completely destroys idea of CUCM's redundancy towards CUBE.
Is there a way to make CUBE treat "403 Forbidden" the same way it treats "486 Busy Here", i.e that it stops going through dial-peers once it receives 403?
Thanks a lot for any suggestion / different point of view
Goran
