Default idle URL for phones on CUCM 10
michael o'nan
Level 4
Level 4
Need to know the default URL Idle parameters for self provisioning. I deleted it and forgot to take a copy and can't find it documented anywhere. Any help would be greatly appreciated!
6 Replies 6
Jaime Valencia
Not sure what you're asking, self provisioning does not require an idle url
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmcfg/CUCM_BK_C95ABA82_00_admin-guide-100/CUCM_BK_C95ABA82_00_admin-guide-100_chapter_01101001.html
java
if this helps, please rate
I already have self provisioning setup with PLAR. For phones that can display the login screen there is a Idle URL under Enterprise Parameters.
Maybe this one:
https://x.x.x.x:443/cucm-uds/xps/selfProvision
java
I hit this on a new cluster on 10.5 - the Idle URL enterprise param wasn't set.  I enabled auto-reg, phone registered but kept trying to query https://ucmpub/cucm-uds/xps/selfProvision, which came up with an error.
Setting the service param did not resolve the issue.  I noticed that this was getting hard-coded into the phone's config.  I traced this back to the Universal Device Template's configuration.  It's another step to change when setting up a new cluster I guess?
In User Management -> User/Phone Add -> Universal Device Template  there is an "Auto-registration Template" created automatically with a certain Idle URL. This template is used by default when auto-registering. So change this, or change the Universal Device Template used when auto-registering.
I got the same issue when I changed the hostname of my server.
However I haven't already found a good URL to provide for having an Idle screen
+5 for pesnexium
