Default password of LDAP synchronized users
Alex9
We synchronized users from company AD and LDAP authentication is not enabled.
My question is what is the default password and PIN for these uses?
Thanks a lot!
balaji.bandi
You need to setup LDAP connection to get the username and password from LDAP ( in general)
If you explain teh context what exactly you looking so we can guide you right direction.
BB
Jonathan Schulenberg
All End/Application user accounts are assigned the password of the their respective default password policy when the database row is first created; for an LDAP account that is the first sync where the user object appeared in the search query results from the LDAP server.
Whatever you set on the password policy - you can’t see it after you set it - is what they got. If the users were already imported your only option is to change the password; you can’t reapply the default after the record exists.
Enabling LDAP Authentication would simply tell CUCM not to use the local salted password, instead passing it through to LDAP for a pass/fail decision.
