06-09-2011 08:47 AM - edited 03-16-2019 05:22 AM
Everytime I install IP Communicator, the default TFTP server is greyed out in the network tab. The only way to get it so that I can edit the network tab fields is to un-install and re-install.
IP Communicator will not register until the TFTP server is there in the network tab - even if you have the right IP address enetered in the NOT the user tab entry. (Even though I have the correct IP addy for the TFTP server there too.)
Anyone have a "tip or trick" to fix that ?
06-09-2011 08:53 AM
Right click CICP icon, run as Administrator, and you will be able to edit preferences.
07-06-2011 01:18 AM
Thanks it solved my problem.
07-06-2011 01:52 AM
Very good, please remember to rate useful posts clicking on the stars below.
