dinorubio
Beginner
Defining preference for SRST phones
can i define a preference for the phones when they register in SRST 3.2?
thanks,
Dino Rubio
6 REPLIES 6
Jaime Valencia
Hall of Fame Cisco Employee
exactly what do you mean by "define preference"?
javalenc
if this helps, please rate
java
when phones start registering with SRST i want to choose what phone register first and so on.
Dino Rubio
Jaime Valencia
there is no way to do that, every phone sends the keepalive every 30 seconds by default. when one looses 3 keepaliveACK from the primary server or when all the list is exhausted they will start sending to the SRST router and that's when they will register.
there is no way on which you can control the exact timing when they will start sending the keepalive to the SRST to register
if you don't want some phones to register to SRST just don't add them the SRST reference.
javalenc
java
Thanks, so i would need to create another device pool with no SRST, right?
Jaime Valencia
yes, for the ones you want to have SRST an SRST DP and for the rest of them a non-SRST DP
javalenc
java
Many thanks!
Dino Rubio
Content for Community-Ad
Spotlight Awards 2021
