05-02-2015 03:57 AM - edited 03-17-2019 02:52 AM
Symptom:
When the Jabber client calls another E.164 number there is a 6 sec delay before the other endpoint rings, this matches the Inter Digit Timeout value configured on cluster.
Also, Jabber does not have a dial-pad and the number is entered in full before placing the call, Enbloc dialing. CUCM should not wait any longer for additional digits and route the call right away.
This issue happens on ALL Cisco SIP Hard Phones as well (99xx, 89xx, 79xx, 78xx, 88xx, EXxx, MXxx, SXxx, C20, C40, C60, C90 etc). But Cisco SCCP phones and third party SIP phones works fine.
The 6 seconds is the interdigit timeout value on CUCM.
Conditions:
Delay occurs during enbloc dialing via pattens including '!'
If we dial a number (Enbloc dialling) that hits the pattern , example : 3130!
In digit analysis we can see below.
Cisco SCCP phone : |PotentialMatches=NoPotentialMatchesExist
Third Party SIP Phone: 1st DA== |PotentialMatches=NoPotentialMatchesExist 2nd DA==|PotentialMatches=NoPotentialMatchesExist
Jabber Client: |PotentialMatches=PotentialMatchesExist
Cisco SIP Phone: |PotentialMatches=ExclusivelyOffNetPotentialMatchesExist
The issue here is the lack of any explicit indication from the SIP endpoint that dialing is complete.
When the user dials while on-hook, then goes off hook, the digits are sent "en bloc" to CUCM.
SCCP sends an explicit indication that the dial string is complete, but SIP endpoints and clients do not.
Workaround:
N/A
05-04-2015 07:19 AM
The behavior that you are noticing is expected. Still you can test it with SIP dial rules, but I believe you will still have the same behavior.
There are several bugs that have been filed for delay in dialing using SIP endpoints: CSCup99586 , CSCtr01695, CSCtq91710 but none is resolved yet.
Workaround:
Eliminate overlapping patterns.
Decrease t302 timer.
Ronak Agarwal
05-08-2015 12:14 AM
thanks for clarify - we cannot delete overlapping patterns - we decreased the t302 timer - the minimum configurable timeout is 3 sec. - customer side complains again
We also warn the customer - t302 timer also impacts call transfer interdigit timeout.
We tested before with SIP dial rules - without success.
We expected that the call handling should be equal or better with the New Phones (88xx) than with the "old" phones (79xx) ...
regards
Alex
04-29-2016 04:39 AM
Hi Alex,
We have the same issue here in Luxembourg with the variable-length dial plan. Did you figure out how to improve the user experience? We recommend to use the # but it's still not as best as with the SCCP phones.
05-16-2016 03:15 AM
Hello Yorick
we are still waiting that cisco solves the Problem with the sip phones (user dials while on-hook then goes off-hook) ...
- CSCup99586 -
Symptom:
Conditions:
Workaround:
N/A
Further Problem Description:
The issue here is the lack of any explicit indication from the SIP endpoint that dialing is compete.
06-30-2016 01:59 AM
hi,
do you know if was it fixed this issue ?
thanks.
11-21-2017 01:10 PM
is there a fix for this? We have 8845 phones and the dial to the h323 gateway takes about 10 seconds. After this time i will see the call on my gateway. After that it signals the call to telco. In overall we have a dial out of 15 seconds delay.
When we dial with # at the end of the number with the phones, we have no delay.
What can we do? We have to use overlap Route Pattern in Germany :((
Any help is welcome!!!
Christian
