11-01-2010 12:51 PM - edited 03-16-2019 01:40 AM
I am experiencing too much dealy while making outbound call on the fxo .I have attached the CUCME Config.Kindly checdk the config for any statments in the below config.
CCME#sh run
version 12.4
service password-encryption
hostname CCME
boot-start-marker
boot-end-marker
card type e1 0 0
logging message-counter syslog
logging buffered 51200 warnings
aaa new-model
aaa session-id common
clock timezone DXB 4
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip multicast-routing
no ipv6 cef
isdn switch-type primary-net5
trunk group analog
voice service voip
allow-connections h323 to sip
no supplementary-service h450.2
no supplementary-service h450.3
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class dualtone-detect-params 100
voice class custom-cptone UAE-CUSTOM-FETEX
dualtone disconnect
frequency 421
cadence 315 315
voice class custom-cptone UAE-CUSTOM-ALCATEL
dualtone disconnect
frequency 425
cadence 375 375
voice class custom-cptone UAE-CUSTOM-SIEMENS
dualtone disconnect
frequency 425
cadence 425 325 250 500
voice class custom-cptone UAE-CUSTOM-ERICSSON
dualtone disconnect
frequency 425
cadence 325 325
voice translation-rule 2
rule 1 /^6/ //
voice translation-rule 9
rule 1 /^\(\)/ /9\1/
voice translation-profile PRFX-NINE
translate calling 9
voice-card 0
archive
log config
hidekeys
class-map match-any AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-any AutoQoS-VoIP-Control-Trust
match ip dscp cs3
match ip dscp af31
policy-map AutoQoS-Policy-Trust
class AutoQoS-VoIP-RTP-Trust
priority percent 70
class AutoQoS-VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
interface FastEthernet0/0
description Connected to LAN
ip address 192.168.124.1 255.255.255.0
duplex auto
speed auto
auto qos voip trust
service-policy output AutoQoS-Policy-Trust
interface Service-Engine0/0
no ip address
shutdown
interface Service-Engine0/1
description Unity Express
ip unnumbered FastEthernet0/0
service-module ip address 192.168.124.3 255.255.255.0
service-module ip default-gateway 192.168.124.1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.124.100
ip route 192.168.124.3 255.255.255.255 Service-Engine0/1
ip http server
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
control-plane
rmon event 33333 log trap AutoQoS description "AutoQoS SNMP traps for Voice Drops" owner AutoQoS
voice-port 0/1/0
trunk-group analog 6
translation-profile incoming PRFX-NINE
input gain 7
cptone CH
connection plar opx 200
impedance complex2
voice-port 0/1/1
trunk-group analog 7
input gain 7
cptone CH
impedance complex2
voice-port 0/1/2
trunk-group analog 8
input gain 7
cptone CH
impedance complex2
voice-port 0/1/3
trunk-group analog 9
input gain 7
cptone CH
impedance complex2
voice-port 0/2/0
trunk-group analog 10
input gain 7
cptone CH
impedance complex2
voice-port 0/2/1
trunk-group analog 11
input gain 7
cptone CH
impedance complex2
caller-id enable
voice-port 0/2/2
trunk-group analog 12
input gain 7
cptone CH
impedance complex2
caller-id enable
voice-port 0/2/3
trunk-group analog 13
input gain 7
cptone CH
impedance complex2
caller-id enable
voice-port 0/3/0
trunk-group analog 14
input gain 7
cptone CH
impedance complex2
caller-id enable
voice-port 0/3/1
trunk-group analog 15
input gain 7
cptone CH
impedance complex2
caller-id enable
voice-port 0/3/2
voice-port 0/3/3
ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer cor custom
name INTERCOMM
name LOCAL
name MOBILE
name NATIONAL
name ISD
dial-peer cor list INTERCOMM-CALLS
member INTERCOMM
dial-peer cor list LOCAL-CALLS
member INTERCOMM
member LOCAL
dial-peer cor list MOBILE-CALLS
member INTERCOMM
member LOCAL
member MOBILE
member NATIONAL
dial-peer cor list NATIONAL-CALLS
member INTERCOMM
member LOCAL
member NATIONAL
dial-peer cor list ISD-CALLS
member INTERCOMM
member LOCAL
member MOBILE
member NATIONAL
member ISD
dial-peer voice 10 pots
trunkgroup analog
corlist outgoing LOCAL-CALLS
description ----- OUTGOING LOCAL CALLS -----
preference 10
destination-pattern 9[23457]......
dial-peer voice 3 voip
description ----- INCOMING CALLS TO VOICE MAIL -----
destination-pattern 500
session protocol sipv2
session target ipv4:192.168.124.3
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 4 voip
service exit
destination-pattern 501
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 12 pots
trunkgroup analog
description -----OUTGOING LOCAL CALLS -----
preference 10
destination-pattern 9[68][0][123456789]....
dial-peer voice 14 pots
trunkgroup analog
preference 10
destination-pattern 9[68][123456789].....
dial-peer voice 18 pots
trunkgroup analog
preference 10
destination-pattern 9[0][4].......
dial-peer voice 20 pots
trunkgroup analog
corlist outgoing NATIONAL-CALLS
description ----- OUTGOING NATIONAL CALLS(PRI) -----
preference 5
destination-pattern 9[0][23679].......
forward-digits 9
dial-peer voice 30 pots
trunkgroup analog
corlist outgoing MOBILE-CALLS
description ----- OUTGOING MOBILE CALLS(PRI) -----
preference 5
destination-pattern 9[0][5][0,5,6].......
forward-digits 10
dial-peer voice 40 pots
trunkgroup analog
corlist outgoing ISD-CALLS
description ----- OUTGOING ISD CALLS(PRI) -----
preference 5
destination-pattern 900.T
prefix 00
dial-peer voice 50 pots
trunkgroup analog
description ----- OUTGOING TOLLFREE CALLS(PRI) -- ---
preference 10
destination-pattern 9[68]00.T
dial-peer voice 60 pots
trunkgroup analog
description ----- OUTGOING SERVICE NUMBER CALLS(PRI) -- ---
preference 10
destination-pattern 9[19]..
dial-peer voice 5 voip
service exit
destination-pattern 502
codec g711ulaw
no vad
telephony-service
em logout 0:0 0:0 0:0
max-ephones 30
max-dn 144
ip source-address 192.168.124.1 port 2000
auto assign 1 to 30
timeouts interdigit 3
network-locale GB
network-locale 1 GB
network-locale 2 GB
network-locale 3 GB
network-locale 4 GB
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7921 CP7921G-1.3.3
load 7941 SCCP41.8-4-4S
load 7942 SCCP42.8-4-4S
load 7961 SCCP41.8-4-4S
time-zone 35
date-format dd-mm-yy
voicemail 500
max-conferences 8 gain -6
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
fac custom alias 0 2345 to 2345
create cnf-files version-stamp 7960 Nov 01 2010 21:14:39
ephone-dn 1 octo-line
number 200
label 200
description Reception
name Reception
ephone 14
no phone-ui speeddial-fastdial
no phone-ui snr
no multicast-moh
device-security-mode none
mac-address 2893.FEA3.3154
type 7962 addon 1 7915-12
button 1:1 2:12 3m3 4m5
button 5m6 6m7 7m8 8m9
button 9m10 10m11 11m15 12m16
button 13m19 14m22 15m25 16m30
button 17m42 18m50
ephone 15
no phone-ui snr
no multicast-moh
mac-address 2893.FEA3.4E56
button 1:1 2:29 3m3 4m5
button 17m42 18m50
11-01-2010 03:01 PM
How much delay ?
11-01-2010 03:13 PM
The reason could be the interdigit timeout configuration, you can try to decrease the value under the port configuration( 3845(config-voiceport)#timeouts interdigit), if after that you still have this delay please collect the following debugs and send it to us "Debug voice ccapi" and "Debug vpm signal"
Please rate this post if was helpful
Walter Solano
11-01-2010 03:44 PM
Unlikely, OP has CME and correctly set interdigit timeout to 3 already.
