Delay in calls
iptsupport
Level 4
Level 4
Hello ,
Lately we experience delay problems .
For example when I hang up the phone it take the phone a few seconds until the call actually disconnect  or when I answer
calls I hear ringback for few seconds before the call actually connect .
It happend randomally in all the phones .
The customer installed cisco edge 340 in the network and when he  connects them for the first time
all the ipcc agent reset . As of right know there are 5 of the working .
System version: 9.1.2.11900-12
Amy idea ?
5 Replies 5
Hi ,
 for a first step ... check in 'RTMT > System Sumary', for any performance issues, like CPU for example.
 Did you find any issue there?
 Hope this helps.
Cpu and memory are low .
The proccess messaging interface is down in PUB.
In system logs I can see this error :
: SELinux is preventing access to files with the label, file_t. For complete SELinux messages. run sealert -l b1b593ba-d6ec-40b8-8d55-4813d787f162
Shadi Shami
Level 7
Level 7
High CPU/ Memory causes this, kindly get the Event Viewer (application and system logs) through RTMT ( Trace & Log Central > Collect Files > Next to go to the 2nd page > check both "Event Viewer-Application Log" and "Event Viewer-system Log" of the server where the phones are registered.
Thank you,
Shadi
Ping the cucm and check the Respons time via CMD.
 did you double check your Switch configuration? In other words, could be a delay caused by the network (as soon as the CUCM's CPU is OK)?
Regards.
