Delay in outgoing(international, Mobile calls) , ring back issue
Yazen Alaa
Good Afternoon
I have router 2912 with Version 15.2(2)T1 , working as H.323 , with 2 FXO's are dedicated with two CEO's and CUCM 8.5  , the problems are
1) Delay in international calls so that it takes around 25 seconds to processed the call.
3) there is no ring back tone only in international calls
2) delay in National or locally calls , it takes around 8 seconds to processed the call
in CUCM
International route pattern:
00[1-9]! prefix : 70 for CEO1
00[1-9]! prefix: 60  for CEO2
Mobile or national Route Pattern
[569]XXXXXXX  prefix : 70
[569]XXXXXXX  prefix : 60
Note : the customer doesnt want to press # after pressing international number 00[1-9]#
how to solve these problems with the best solutions ??? and the configuration in below :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-throug
h g711alaw
h323
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description ## To WT-6513-01-Gig9/8##
ip address 192.168.xx.x 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.xx.x
ip route 0.0.0.0 0.0.0.0 192.168.xx.x
control-plane
voice-port 0/0/0
cptone KW
connection plar opx 35555
description ## 224399942- CEO1 ##
caller-id enable
voice-port 0/0/1
cptone KW
connection plar opx 38086
description ## 22455326-CEO2 ##
caller-id enable
dial-peer voice 200 voip
description **Dial-peer to CUCM-SUB**
preference 1
destination-pattern 6300.....
session target ipv4:10.188.240.10
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 201 voip
description **Dial-peer to CUCM-PUB**
preference 2
session target ipv4:10.188.240.11
voice-class codec 1
no vad
dial-peer voice 301 voip
description **Dial-peer to CUCM-PUB - IVR 1805555**
preference 2
destination-pattern 1805555
voice-class codec 1
no vad
dial-peer voice 100 pots
description ## 224399942 ##
destination-pattern 70T
port 0/0/0
dial-peer voice 99 pots
description ## 22455326 ##
destination-pattern 60T
port 0/0/1
dial-peer voice 401 voip
description **Dial-peer to CUCM-SUBfor CEO1**
destination-pattern 38086
voice-class codec 1
no vad
dial-peer voice 402 voip
description **Dial-peer to CUCM-PUB for CEO1**
preference 2
voice-class codec 1
no vad
dial-peer voice 420 voip
description **Dial-peer to CUCM-SUB for CEO2**
preference 1
destination-pattern 35555
voice-class codec 1
no vad
dial-peer voice 422 voip
description **Dial-peer to CUCM-PUB for CEO2**
preference 2
voice-class codec 1
no vad
Your answer is very important for me
Thanks and regards
9 Replies 9
Yazen Alaa
the Customer doesnt want to press # after press international call
00[1-9]!#
Please I need best Answer ASAP
Best Regards
Bruno Rangel
Hi Lkayyali2011
Try modify the T_302 parameter which is the interdigit timeout in CUCM service parameters (I hope the default is 15000ms).
Please remember to rate helpful  responses and identify helpful or correct answers.
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
thnaks for ur reply
it was configured  before to 6000 , but the same problem ,still  there is delay ????
and regarding no ring back tone when i make international ,????
Have you changed in the Service parameter the T302 Timer?
Cheers
Bruno Rangel
Already configured but  still there is delay
second question , regarding there is no ringback tone when i make international call only why ????
thnaks
problemchild27
      In Service parameter change the T302 timer to 5000, Default is 15000
Thank you
      PC
thanks for ur reply
thnaks
For issue with Ring back look in this thread.
Cheers
Bruno Rangel
                       Hope the attached doc should be useful to you in fixing the issue.
Thank you
      PC
