Delay ring
randall66
I am converting users from an NEC system to CUCM 8.0 and they are requiring a function they call ring delay.
It rings a phone and after a certain amount of rings, rings other phones two more times while still ringing the first phone if no one answers it goes to the Vm of the first phone DN. I can not find any function in call manager that does this except hunt groups. Any ideas.
Jaime Valencia
There is no equivalent, as you've found you would need to configure CFNA to s hunt pilot with a broadcast line group that includes the called phone.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
