AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
145
Beginner
Delete DLU's
Hi Everyone,
Can anyone tell me how to delete DLU's from CUCM 7.1(5) ?
I have recently rebuilt a CUCM 7.1(5) Publisher using a DRS Backup offline ready to move into Production as part of a Cluster move project and received a new Licence file from Cisco Licensing which "rehomed" the original licenses to the new Publisher MAC address.  I loaded this license onto the Publisher and it has doubled the DLU and Licensed Server count !!
As this server is offline, I have deleted all licenses files, restarted the License Manager Service and even rebooted the server but the DLU's and Server licenses still show in the License Report and still double the customers entitlement.
How can I reset all License counts to zero so I can reload the new license file and have the Publisher showing the correct license entitlement ?
Note that at this time, there is no upgrade planned to CUCM 9.x therefore any solution using ELM is not applicable.
Many thanks,
Matt
5 REPLIES 5
Delete DLU's
Hi Matt,
Did you try deleting the licenses from the CLI using 'file delete license ' command?
If they are still reappearing then this may need a TAC case to be opened to delete them by using root access.
Manish
Beginner
Delete DLU's
Hi Manish,
yes I did that and no license files are showing on the server through the CLI and in the Licence Upload menu in CUCM Admin GUI.  As far as I can see there are no license files at all on the server yet the License Unit Report shows 1000's of DLU and currently 12 Servers !!!
Matt
Delete DLU's
Hi Matt,
As you have already tried restarting the server as well i will suggest opening a TAC case as i have seen such instances where licenses need to be deleted from root and only TAC can provide root access.
Manish
Highlighted
Beginner
Delete DLU's
Thanks Manish,
I was thinking that would be the only way out of this.  I'll speak to TAC and hopefully they will be able to help.
Matt
Advisor
Delete DLU's
Hi Matt,
Agree with Manish[+5].
ELM has been introduced from CUCM version 9.x .
regds,
aman
Content for Community-Ad
August's Community Spotlight Awards
