09-05-2013 02:48 PM - last edited on 03-25-2019 08:25 PM by ciscomoderator
I would like to make a lab with CUCM 9.1 installed in VMWare virtual environment for testing purposes.
I see that I can request a DEMO license through http://cisco.com/license but where do I download the installation files from?
Regards.
09-05-2013 03:03 PM
No media is available to download.
The official eval media is to be paid for, and only UC certified partner can buy it on some obscure website, that I can't even find anymore
Very illogical.
09-05-2013 04:53 PM
http://www.cisco.com/web/partners/sell/promotions/uc_system_release_nfr_program.html
Guess Paolo means the above, but as he says, this is not publicly available
Eligibility | Cisco Unified Communications Advanced and Master Specialized Channel Partners, Cisco Unified Communications Learning Partners, and Cisco Technology Development Partners. |
If you search CSC you might find the method to turn the images from CCO into bootable media, obviusly there won't be any kind of support if you do so, but if all you want is to lab something, you might want to try it. The stability of the product cannot be guaranteed, basically, you would be on your own if you have any issues. At least from a Cisco support perspective.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
