08-28-2013 04:20 AM - edited 03-16-2019 07:04 PM
Does anybody knows in a CUCM 9.1 with a demo license, how many devices i can install? in cucm 8.X for example in system > licenses i can see how many DLUs i have and how many devices can install, in cucm as work with CUWL does not show anything, all is 0 as show
In ELM i can not see anything.
Thanks!
Solved! Go to Solution.
08-28-2013 07:33 AM
You can get a six month demo license at cisco.com/go/license with the following licensing:
Cisco Unified Communications Demo License Version 9.x | |
- 20 CUWL PRO Unified Communications Manager licenses - 20 CUWL PRO Unity Connection licenses - 5 TelePresence Room licensesPlease note: The term for this demo license is 6 months |
08-28-2013 06:23 AM
I don't believe there's any limit, and remember DLUs no longer exist in 9.X
With a fresh install you get a 60 days grace period over which you can configure the system and have services running, past those 60 days, the system will no longer work unless you upload a valid license.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-28-2013 07:33 AM
08-28-2013 08:12 AM
The default 60 day demo license has no limit, this allows migrations where licensing may take some extra time to get worked out.
HTH,
Chris
09-23-2013 02:27 AM
Hi one question.
After installa the demo license in my cucm 9 in vmware , in a mock-up, few days later my cucm get crashed and i needed to reinstall all again, now the same steps to get the license fails, and I have a TAC with cisco to resolve it, my question is, now all phones are unregistered and i am no able to register, even my CIPC is unable to register, there is no a issue with pings, os something else because all is as before the reinstalling.
So, i a cucm 9 without demo license is no possible to register phones?
thanks!
11-06-2013 11:54 AM
So how about for people that want to build labs what happen after 6 months ? I mean do they need to keep rebuilding the entire setup after it expires ?
11-06-2013 12:17 PM
Yes, the software is not meant for lab purposes without a license, you can purchase NFR kit if you are eligable or you will need to order proper license.
HTH, please rate all useful posts!
Chris
09-06-2013 02:09 AM
Thank you Brad, it runs perfect!
10-16-2013 03:26 AM
Hey guys,
i'm wondering what to enter in the field "License Request"?
When i`m trying to add an entry to the Enterprice License Manager (License Planning) i can't order a
DEMO License. So i add "Standard License" but there is still no content which i could paste to the "License Request"-field.
I think i probably get something wrong here.
I just want to know how to get the Demo License from the CCO to the Communications Manager (v9.1).
Best regards!
10-16-2013 03:49 AM
May be you could try with a demo license from ccx 85, open it and change 8.5 to 9.1 and test.
In the .txt the Mac add is FFFFFFFFFFFF so it should run.
regards.
