destination-pattern # needed
J_Vansen_S
Level 3
Level 3
Hi all; I am currently running CCME with 4FXO lines. The customer needs to make a call starting with #. Whenever 9 followed by # is pressed a busy tone is heard.
Below is my dial peer config.
dial-peer voice 10 pots
Destination pattern 9.T
Please advise how I can configure my destination pattern to take # type.
Can you try changing the termination digit to something other than # using this command?
dial-peer terminator
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_d1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1114770
6 Replies 6
Roman Rodichev
Level 7
Level 7
Did you try destination-pattern 9#T ?
# is used as a default termination key for the T pattern. Instead of waiting for inter digit timeout CME will match the pattern when # is pressed. I don't believe you can change this key, but I suspect if you use it in the middle of the pattern it will be treated as a #-key. This behavior is similar in CUCM.
J_Vansen_S
Level 3
Level 3
Yes # is the default termination. Thus it does not work. # can't be use as a middle number key in my scenario. It has to be 9 followed by #. Any workaround or solution to this?
Could you try
destination-pattern 9.T as workaround
Pierre.
Sorry, I meant:
destination-pattern 9#.T
Pierre.
THANK YOU~! Anthony...
dial-peer terminator works!
Ive replaced # with alphabate F.
Problem Solved.
