Determine what version OVA was used to install CUCM
rcrumm_2
Level 2
Level 2
Is there a way to determine what version OVA file was used when the system was set up initially?
I can see in the tasks that an OVF file was deployed, but I do not see what version file.
Randall
Jaime Valencia
If you mean V7 vs V8, that's up to the ESXi version.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
version 7 is for ESX 4.x, and version 8 is for ESX 5.x
Anas
please rate all helpful posts
According to the RN for 9.1.2 it says v1.6 or older can have an issue with aligned partitions.
Oh, you meant that one, no way to tell once it's deployed.
java
java
