03-17-2014 12:06 PM - last edited on 03-25-2019 08:28 PM by ciscomoderator
Installed device pack device pack 9.1.2.12028-1 last week. Now I am getting complaints from 7962 users with headsets stating that while in headset mode they cannot transfer a call. They are stating that when they press the transfer button it simply puts the person on hold with no ability to dial digits.
If I take them out of headset mode the transfer feature returns.
If I downgrade from SCCP42.9-3-1SR4-1S to SCCP42.9-3-1SR2-1S transfer functionality retuns in headset mode.
Any ideas? Or is this a bug?
Solved! Go to Solution.
03-18-2014 07:00 AM
Hi there,
I'm not sure how this is marked as "fixed" .....
03-17-2014 12:31 PM
Ok I can confirm that when I downgrade the phone from SCCP42.9-3-1SR4-1S to SCCP42.9-3-1SR2-1S the transfer functionality returns.
03-18-2014 07:00 AM
Hi there,
03-18-2014 07:06 AM
I think this is a fantastic workaround: - Do not use a headset
Really?
03-18-2014 07:28 AM
Hi there,
Tell that "workaround" to your users probably won't fly I'm guessing!!
I might open a TAC case to see if they have a "fixed-in" version available for special download.
Cheers!
Rob
07-30-2014 12:11 PM
I know this is 4 months old, but I just wanted to follow up. Had the same issue on 79XX phones with headsets, today.
Opened a support ticket with TAC, received a fixed firmware version.
The Cisco Caveat Id for this issue is:
CSCun26289 | Problems transferring/answering calls when using headset with 79XX phone |
The updated version is SCCP45.9-3-1ES27S
The 'transfer' seems a little off still, but it does work. The headset almost disconnects, then immediately reconnects. Seems to add about 2 seconds to the transfer time once users are used to the issue.
