I got a Customer who is still using CUCM version 9.1.2. We are currently planning to migrate them to 12.5.
They have also a lot of ATA187 ( around 150) which will be replaced by ATA191. Now the plan is to replace ATAs first and then Migrate the Cluster to the new CUCM Version. Unfortunately, I am unable to find which device pack included support for ATAs192 on CUCM 9.1.2. According to the compatibility matrix, ATA191 should be supported with this CUCM version. There is of course no way to download it form Cisco since it is End of everything since 2017.
So does anyone has this Device package and is willing to share it? :) I would appreciate any help or suggestion.
Thank You
