09-15-2019 05:24 AM
All the registred phones are continiously sending DHCP request (option 53)
is that normal or there is a way to stop this ?
09-15-2019 05:47 AM
This will be processed for the phone first come online and try to DHCP IP address and register with CUCM (if you set up correctly)
are this messages you see after you getting the DHCP IP and also register with CUCM ? or Phone never registering?
here is the reference guide for DHCP 53 and other options in case required to refer :
09-15-2019 07:13 AM
HI,
Are this messages you see after you getting the DHCP IP and also register with CUCM ? or Phone never registering?
The phones are registred and working .
the packet are captured from the pc which is connected to the phone
