09-14-2017 03:36 PM - edited 03-17-2019 11:10 AM
If there is 2 call manager servers. One for contact center and one for non contact center. Do i need to configure 2 different dhcp voice scopes...one for each tftp server? Or can i just create one dhcp voice scope and configure 2 ip addresses for option 150?
Thank you for your help
Solved! Go to Solution.
09-14-2017 06:07 PM
Then you need a scope for each cluster
09-14-2017 05:24 PM
Are you talking about servers in the same cluster??
Or different clusters?
09-14-2017 05:38 PM
09-14-2017 06:07 PM
09-16-2017 07:33 AM
Since I do this exact thing another approach is Proxy TFTP under Advanced Features.
1. Make sure at least one of the cluster ID's is defined
2. Set 1 cluster as your primary
3. Set the other cluster as secondary TFTP addresses from the primary
4. Point Opt150 at your primary
Works great and I do this between a 9.1(2) cluster and a 10.5 PCCE cluster.
