I had a CISCO 7940 IP phone with Callmanager and when I needed to dial, I pressed dial pad without pickup handset. Then, I pressed the dial button and call was maked using speaker.
Now, I converted the ip phone to SIP firmware (version P0S3-8-12-00), but now I need to pickup handset before use the dial pad.
Can I dial numbers without pickup handphone or use speaker, with SIP firmware of IP phone 7940?
The dial pad doesn't work before I pickup handset?
Thank you.
Marcus Vinicius
