dial-peer and debug issue explanation
kartik.bhatia
A new lab setup
2821 router with 2 E1 ports and a back-to-back E1 connected between them - on the same router
Both ports Up & Multiple_Frames_Established.
Well the Call is Ringing & getting connected - I just do not understand how and why is the debug dialpeer and debug isdn coming out so wierd.
IpPh1 - DN 1501
IpPh2 - DN 07531883443
A Route pattern 9.xxxxxxxxxxx in CUCM poiting to the H323 GW.
Call from IPPh1 1501 to IpPh2 07531883443. I want the call to go via the route pattern, hit the H323 GW and match the dial-peer:
dial-peer voice 1 pots
destination-pattern 0T
port 0/2/0:15
forward-digits 11
and then come put the other side E1 port, match incoming called-number . dial peer and then:
dial-peer voice 2 voip
destination-pattern T
session target ipv4:10.10.10.10
I did not put a 0T here as I wanted the call to get a better match with dial-peer 1 pots and go out the E1 port - which it is doing - alleast I think so.
The ISSUE:
I see this single call getting connected 3 times - I see 3 setups, I see Interface Serial0/2/0:0 is now connected to 07531883443 AND Interface Serial0/1/0:1 is now connected to 1501 3 times
I know I have 3 channels configured - but why is every channel getting connected?
What wrong am I doing please?
Assist. sh run and debugs attached.
linuxchild
I feel that there is a loop , this a pb of B chanelles
the idea is to have a
  • incoming VOIP dial peer (for calls from call manager to your gateway)
  • outgoing pots (from gateway to PSTN  )  PST for you is your gateway
  • incoming pots (from PSTN to gateway )PST for you is your gateway
  • outgoing voip (from gateway to callmanager)
so try the following dial peer
dial-peer voice 1 voip
dial-peer voice 2 pots
port 0/2/0:15
forward-digits 11
dial-peer voice 3 pots
direct-inward-dial
dial-peer voice 4 voip
if this did  not correct it can you make establishing the call and during the active call
sh call active voice brief
Hi linuxchild
It did not help ... but I found this:
I had 3 dial peers already - you asked to me add 'dial-peer voice 1 voip; incoming called-number .' as well - but I thought this was being taken care by the default dial peer already.
I think - but you correct me if I am wrong - The reason I was getting this loop was because destination-pattern 0T was getting matched going when I dialed 07whatever originally - then this 07 number coming out on the other side E1 port was also matching this same dial-peer and taking the second channel and then again the third channel.
So sh call active v brief was showing 6 active call legs.
I changed destination-pattern 0T to destination-pattern T so that both dial peer are equally matched - this resolved it - I see 2 active call legs in sh call active v brief and debugs are coming out all right now as well.
BUT I am still confused that when I dial 07whatever - since both dial peers are exact & equal match being destination-pattern T - why does the router picks up the pots dial peer first and when this call comes out on the other side E1 on the same router - how and why does it match the voip dial-peer to give the call to the call manager.
How is the router intelligent enough to do this on its own - any ideas please?
Thanks & Regards,
Kartik Bhatia
I will answer your first question
It is not recommanded to match the dial-peer Zero , (the default dial-peer) , not good practice
for the second question give me some time , I will try to simulate it is my lab tonight or this weekend and let you know
nitsinha
Level 4
Level 4
Hi Kartik,
Whenever two or more dial-peers have equal preference(in your case preference 0), the gateway will use the dial-peers in round-robin fashion starting with the one which was created first. Hence in your case, when the outbound dial-peer has to be matched to route call out the pots line, the gateway matches the dial-peer 2 pots(since this was created first). Similarly when the call comes in from the pots line and has to be sent to the CUCM, the router uses dialpeer 4 voip since it has to use the dial-peers in round-robin order. Next time when you make a call, it again uses pots first and then voip.
Nitesh
PS:Please rate helpful posts
